@ 250K miles, what should I have done to go another 250K?
rich121
Yakima, Washington State
2005 Golf GLS TDI
Looking to spruce up my 2006 Golf.
I know the weak link is the cam, so is this something I should have upgraded?
Also wondering about Turbo/clutch/tuner upgrade from Kerma:
And a mechanic in the Oregon/Washington area to do the work... recommendations would be greatly appreciated.
Mozambiquer
Versailles Missouri
In my opinion, there are a lot better and cheaper options than kermas kit. There's really not much that comes with it for $2500.
For longevity, a Franko6 cam, a vnt17 turbo (even the stock one is fine for longevity) a light tune and I'd leave the egr stock.
Then maintain it, replace the timing belt every 80k miles as specified, use only 505.01 spec oil, maybe put cera-tec in it and do a fuel purge.
If you don't have a skid plate, put one of those on.
BobnOH
not-a-mechanic
central Ohio
New Beetle 2003 manual
The early PDs with cam issues was often the result of people, especially dealers, using the wrong oil.
Either way I would not preemptively change it ( though they could be hard to find in 5 or ten years). Do inspect it from time to time. It's not a brake rotor, it should show little to no wear.
If you want it to last, keep it stock. And all PD cams come from the same manufacturer these days, except for cast cams which may come from anywhere. But billet cams are all made by Estes in Turkey, regardless or packaging.
CantWrite
Placerville CO
2005 Passat Wagon (BHW/5-spd conv, 03T). I keep in touch with the (2) ALH's I sold.
Define “spruce up” as it means different things to different people.
My 2003 Jetta Wagon, I did an entire suspension/bushing refresh right around 250k and the car drove like new!! I stupidly sold it.
Interior update with better seats...suspension refresh, stereo upgrade, a monthly detail, power upgrades.....do give it the maintenance it deserves.
I just did the TB on my ex-2002 NB at 365k miles. Headed towards 450k now, PP520’s, S7, and tune. It gets all it needs, owner wants to take it till the odometer stops.
Your car looks beautiful, I’d say keep doing what you’re doing. But do something that will keep your attraction to it, instead of looking for greener pastures.
