2023 TDIfest/GTG discussion thread
thecrusher773
Coweta, OK
2002 5 Speed Beetle-sold, 2010 Jetta-sold 2014 Beetle
I live just outside Tulsa I am sure we could find somewhere. If we had to I have 5 acres and the space depending on how many would be coming. There is also a public baseball field/park right by my house with 2 entrances and a wide gravel road through it. We could easily park on each side of it and walk up and down and look at cars.
  • Like
Reactions: Ton
DieselBunny
Illinois
2013 JSW 6MT LP7W
My wagon is almost ready for trips. Still trying to get my leaking pano roof sorted.. Gonna be dropping the headliner and rtv sealing anything I see that leaks.
  • Like
Reactions: Ton
AndyBees
Southeast Kentucky
You need to find the discharge end of the drain pipes. The ends are puckered to keep out insects. The pucker causes debris to pile-up and then water backs-up to the top and overflows into the ceiling upholstery. I trimmed off the bottom of the drain hose. I used a stranded 14 gauge wire to unplug the drain hoses by pushing up from the bottom. Do not use compressed air........ if you blow-off the hose at it's connection to the tray, you'll be in for some serious work to correct the problem.
There are drains on all four corners.
I've had to deal with this problem on my 2003 Jetta and my 2011 Tiguan.
MrCypherr
Ontario
Mk6 Wagon
Almost end of the year, Before it gets too cold should be a good idea to get something going !
