2023 emissions update on a Mk6 TDI?
MrCypherr
Ontario
Mk6 Wagon
I know alot of people have switched to the 2.0T Atlas oil pans which isnt plastic as a "OEM" swap. I know that the 2.0T 2018+ Tiguans have issues with the PCV failing and either blowing out the timing chain cover gasket, oil pan slightly cracking and throwing a EVAP fault due to the sensor throwing way out of spec because of the excessive pressure.
pedroYUL
MI, USA
2015 Passat CVCA; 2015 GSW CRUA; 2004 wagon BEW(brother)
I'm still waiting to get this car back from the dealership...gosh these guys are slow!
MrCypherr
Ontario
Mk6 Wagon
I'm very surprised its taking them this long, But I know alot of dealers are backed up with stuff lately. When did you drop it off?
pedroYUL
MI, USA
Monday June 10 at 8 am I dropped it off, but they were short handed and didn't get to diagnose it until Tuesday.
Just called to see if it was ready by EOD today... nope.
pedroYUL
MI, USA
This car is finally fixed! I will report back here once I drive it a bit.
Edit: after some 100 miles of testing, I think this car is now fixed good. No regen yet, but that should be good too.
Edit again: 300 miles and I didn't detect the regen, but it probably happened in the highway. Running pretty good, although something is still loose in the front end, I'll look at replacing the left side tie rod end, inners seemed fine.
pedroYUL
MI, USA
Yup, the left side tie rod end finally fixed a sloppy front end...well, that and the other tie rod end, ball joints, LCA rear bushings, and torsion bar links.
A new DPF is such a beautiful thing! Opened the elbow that feeds the intercooler, expecting to clean some sludge (since every time I have opened there I do find gray/black/green sludge), but this time around was almost pure water, not a lot, maybe a tablespoon.
Before finally getting the new DPF from warranty, I though maybe the turbo was a goner, but now I know the turbo is well. This car has a new lease on life for quite some time. As the end of the warranty approaches, or this new DPF dies again, I'll be getting a non-delete tune for it, perhaps @burpod is ready by then lol.
FJ40Jim
Lancaster, Ohio, USA
'01 Golf GLS 5MT, '12 JSW DSG
Just checking in here out of morbid curiosity.
Glad to hear wife's old car is still running good. You've definitely shown some perseverance in dealing with the emissions crap, getting recall done and getting dealer to honor the emissions warranty.
I'll buy you a :coffee: coffee next time we're in MI.
pedroYUL
MI, USA
Perseverance is one of my best attributes...depending who you ask 😂
MrCypherr
Ontario
Mk6 Wagon
Personally, If everything was covered for free and I was given some sort of rental, I wouldnt mind the wait. Although the back and forth would be annoying but at the end of the day, look at the cost of everything thats getting replaced and look at what youre paying.
pedroYUL
MI, USA
It was some level of back and forth with 2 dealers, but they both furnished loaners each time. Then returning the airbox to its original status took some time. Cleaning/drying the EGR filter a couple of times, putting just the right amount of miles to take it in.
Finally waiting for the CEL to come back 2 times, till they finally changed the DPF.
You are absolutely right on the cost of things, I had to sign paperwork for the dealer to get paid by VW: around $3500 the first time, then $2500 for the DPF replacement. Can't complain!
MrCypherr
Ontario
Mk6 Wagon
Nice thing is, youll have warranty on every part they replaced. Not sure how the warranty is in the states but I'm sure its 2 years or something.
pedroYUL
MI, USA
Remember, this car just got extended emissions warranty activated some maybe 1k miles ago and 4 months tops. The extension goes for 4 years or 48k miles.
Maybe 🤔 I should sell and get another 1.4t EA211, problem is finding one reasonably priced.
lemoncurd
PNW
2013 CJAA GTB2266
I know it "can" be, but afaik there's no repository out there with original tunes. That's why i say this guy needs to back his up & preserve it like a monk living on a Greek cliffside monastery. Otherwise he'll need to find a darkweb site in Belarus (which likely will have all Euro versions but no USA code) or buy it "back" from some shyster tuner who didn't write VW's code, but simply copied it.
I've seen the issue discussed here once, but it went nowhere.
MrCypherr
Ontario
Mk6 Wagon
Oh shoot! I forgot you mentioned that awhile back. Thats even better. Thats a huge selling point as well.
pedroYUL
MI, USA
Guess what guys and gals...this car just popped the same DPF efficiency below threshold and EGR insufficient flow codes. Just booked an appointment with the dealer, but this should be some sort of record!
pedroYUL
MI, USA
Went in this morning. Another DPF...this is insane!
Hehe... yup. Fun stuff. They've clearly gone from bad to worse with the "update" to make them run "cleaner".
Could be worse, could be all the VR6 Atlas engines and their chronic Magnetti Marelli injector failures:
Anymore, I'm convinced it's pretty much all junk. We had TWO GM 6.2L V8s in the shop at the same time, both needing the camshafts and valve train rebuilt. They chew themselves to bits sometimes before 70k miles. 0w20 and AFM for the win! Yes, your giant V8 *can* get up to 20 mpg! But not for long.... :D
pedroYUL
MI, USA
Got it back today. 1st warranty DPF at 162,715 miles, 2nd at 163,934 miles.
That's absurd!
