markward
Hello, had an owner in today. He has installed larger diameter tires on his 2016 Touareg and the speedo is reading slower than actual verified with GPS. Using VCDS and you tube, we had no success using long coding or adaption in the instruments section of the software. No obvious solution in the ABS module either. Has anyone figured this out for a 2016 model? Would appreciate specific directions or to know if its even possible. I did search prior. Thank you in advance. Mark
