DanG144
Well, come on down. You are far from home? Tell Bruce and Eric hello.
Brad,
If you want to wait, I have the word that the NOx sensor is a GTG level job. So count on doing it at the GTG.
I just wanted to ensure the instructions weren't "remove the engine and transmission, then cut the compartment open...".
Wednesday,16,December,2015,17:11:45:63363
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 15.7.2.0 (x64)
Data version: 20151124
www.Ross-Tech.com
VIN: 1VWCN7A39CC019016 License Plate:
Mileage: 126420km-78553mi Repair Order:
Chassis Type: A3 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F
52 56 62 72 77
VIN: 1VWCN7A39CC019016 Mileage: 126420km-78553miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CKRA) Labels: 03L-906-012-CKR.clb
Part No SW: 03L 906 012 BP HW: 03L 907 309 S
Component: R4 2,0L EDC H21 7445
Revision: 71H21--- Serial number:
Coding: 001D0012042400008000
Shop #: WSC 57857 001 1048576
ASAM Dataset: EV_ECM20TDI01103L906012BP 004009
ROD: EV_ECM20TDI01103L906012BP.rod
VCID: 73E56926DA42ABA666-8026
2 Faults Found:
9688 - Reductant Tank Temperature Sensor
P205B 00 [237] - Implausible Signal
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 116712 km
Date: 2015.08.21
Time: 04:13:12
15733 - SCR NOx Catalyst Bank 1
P20EE 00 [096] - Efficiency too Low
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Readiness: 1 1 0 0 0
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 054 C HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2806
Revision: 05351113 Serial number: 00001105130587
Coding: 0000020
Shop #: WSC 09003 957 00200
VCID: 162370B221701E8EA1-8042
No fault code found.
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: C54BC0F549230003A30B03E5921F0042A70000
VCID: 7BF54106FA12E3E63E-802E
Address 05: Acc/Start Auth. (J518) Labels: 5K0-959-434.clb
Part No SW: 5K0 959 434 B HW: 5K0 959 434 A
Component: VWKESSYPQ35GP 085 0902
Revision: 00085000 Serial number: 0149961923
Coding: 130C0C
ASAM Dataset: EV_KESSYPQ35G A02014
ROD: EV_KESSYPQ35G.rod
VCID: 3467AA3A9FCCEC9EBF-8060
1 Fault Found:
1057547 - Antenna for Keyless Entry System; Interior Antenna 1
B1172 13 [008] - Open Circuit
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 123
Mileage: 124247 km
Date: 2015.11.20
Time: 01:38:43
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 561 907 044 D HW: 561 907 044 D
Component: Climatronic H01 0102
Revision: 00001001
Coding: 0010001012
ASAM Dataset: EV_ACClimaBHBVW411 A01001
ROD: EV_ACClimaBHBVW411_VW41.rod
VCID: 183F7E8AE36428FEB3-804C
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 087 Q HW: 5K0 937 087 Q
Component: BCM PQ35 H+ 111 0148
Revision: BL111001
Coding: 6F200E3FF82B08D408880201360009E000F5008045A005F0E9846004BC70
VCID: 4385F9E6C2625B2636-8016
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 100911 05 54 0403
Coding: 06300A
2 Faults Found:
02745 - Bulb for Daytime Running Light; Left
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 2
Fault Frequency: 30
Reset counter: 158
Mileage: 116697 km
Time Indication: 0
Date: 2015.08.20
Time: 14:56:46
Freeze Frame:
Term 15 On
Voltage: 13.50 V
ON
ON
OFF
OFF
ON
02746 - Bulb for Daytime Running Light; Right
Freeze Frame:
Fault Priority: 2
Fault Frequency: 30
Reset counter: 158
Mileage: 116697 km
Time Indication: 0
Date: 2015.08.20
Time: 14:56:46
Freeze Frame:
Term 15 On
Voltage: 13.50 V
ON
ON
OFF
OFF
ON
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5C0 959 655 HW: 5C0 959 655
Component: AirbagVW10G 013 0809
Serial number: 003ENM003UT
Coding: 00003548
ASAM Dataset: EV_AirbaVW10SMEVW360 A01024
ROD: EV_AirbaVW10SMEVW360_SE36.rod
VCID: 6FED6556B66A8F4682-803A
Seat occupied recognition:
Subsystem 1 - Part No SW: 5C6 959 339 HW: 5C6 959 339
Component: BF-Gewichtss. H10 0027
Serial number: 6940000Y1100007D7T0P
Coding: 303252
Crash sensor for side airbag; driver side:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME6D481542ZZZ-
Crash sensor for side airbag; front passenger side:
Subsystem 3 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME68260362ZZZR
Crash sensor for side airbag; rear; driver side:
Subsystem 4 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Fahr.H H02 ----
Serial number: 3516KSME7C1A6C11ZZZ$
Crash sensor for side airbag; rear; passenger side:
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Beif.H H02 ----
Serial number: 3526KSME3D1B3513ZZZU
Crash sensor for front airbag; driver side:
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Fahr H02 ----
Serial number: 3556LSME0C573E0FZZZ7
Crash sensor for front airbag; front passenger side:
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Beif H02 ----
Serial number: 3566LSME415C3E0FZZZ6
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 1K5 953 521 AR HW: 5K0 953 569 E
Component: LENKS.MODUL 014 0140
Revision: FF010040 Serial number: 20110710200404
Coding: 001A140000
ASAM Dataset: EV_SMLSNGVOLWSXS A01004
ROD: EV_SMLSNGVOLWS.rod
VCID: 7DF14F1EEC06EDD600-8028
Multi Function Steering Wheel Control Module:
Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D Labels: 3C8-959-537.CLB
Component: E221__MFL-YVJ H06 0022
Coding: E30000
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 561 920 970 C HW: 561 920 970 C
Component: KOMBI H07 0507
Serial number: 00000000000000
Coding: 231E01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04093
ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
VCID: 1A3B64821D683AEE85-804E
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 K HW: 1K0 907 951
Component: J533 Gateway H40 1620
Revision: H40 Serial number: 11091101290992
Coding: 461000
VCID: 387F9E0A8BA408FE93-806C
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H07 0507
Serial number:
Coding: 000007
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
VCID: 6ADB74428D886A6ED5-803E
Address 2B: Steer. Col. Lock (J764) Labels: 5K0-905-861.clb
Part No SW: 5K0 905 861 A HW: 5K0 905 861 A
Component: ELV-PQ35 H20 0230
Revision: 00000000 Serial number: 11000187751005
Coding: 4900000000000000
ASAM Dataset: EV_ELVMarquMPVW36X A01001
ROD: EV_ELVMarquMPVW36X.rod
VCID: 2E53B85271E0C64EC9-807A
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Component: SG EXT.PLAYER H13 0240
Revision: A1001003 Serial number: 7660712349
Coding: 010000
VCID: 29594B4E400EA1761C-807C
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 561 959 760 HW: 561 959 760
Component: MEM-FS H04 0181
Revision: AA000000 Serial number: 00000013696834
Coding: 00581B0000000000000021010100202020202120202020
VCID: 60CF166A73B4203E0B-8034
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 3C8 035 684 E HW: 3C0 035 684 E
Component: RNS-MID H59 3690
Revision: AB001001 Serial number: VWZ6Z7L6212127
Coding: 0409000201000094000B
Shop #: WSC 07346 444 10517
VCID: 2D51BF5E74E6BD56F0-8078
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 207
Reset counter: 117
Mileage: 116696 km
Time Indication: 0
Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 561 959 701 A HW: 3C0 959 793 C
Component: TUER-SG FT 002 0525
Revision: 12110009 Serial number: 0003260051
Coding: 0405FD
ASAM Dataset: EV_TSGFPQ25BRFVW46X A04001
ROD: EV_TSGFPQ25BRFVW46X.rod
VCID: 1C37629A175C44DE97-8048
Slave Driver:
Subsystem 1 - Part No SW: 561 959 811 HW: 561 959 811 Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG_HL 004 4472
Serial number: --------------------
Coding: 800000
1 Fault Found:
67584 - Warning Light for Front Door
B11F5 01 [009] - Electrical Failure
Freeze Frame:
Fault Priority: 2
Fault Frequency: 119
Reset counter: 118
Mileage: 116697 km
Date: 2015.08.20
Time: 14:56:14
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 290 3201
Revision: 00H20000
Shop #: WSC 01357 011 00200
VCID: 3467AA3A57CCEC9EBF-8060
Address 47: Sound System (R12) Labels: 5K0-035-456.clb
Part No SW: 3T0 035 456 B HW: 3T0 035 456 B
Component: KonzernAmp10K H06 0362
Revision: -------- Serial number: BP225319882084
ASAM Dataset: EV_AudioVerst10KanalSTT3 S01001
ROD: EV_AudioVerst10KanalSTT3.rod
VCID: 306FA62A6BD4D0BEDB-8064
Address 4F: Centr. Electr. II (J520) Labels: 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H40 1620
Coding: 01020108
VCID: 6FED6556BE6A8F4682-803A
Subsystem 1 - Part No SW: 561 959 591 HW: 561 959 591
Component: J245 P05 FFD7 H07 0004
Coding: 181100
Subsystem 2 - Part No SW: 561 919 204 B HW: 561 919 204 B
Component: Analoguhr 008 0002
Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 561 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0525
Revision: 14110009 Serial number: 0002916333
Coding: 0405FC
ASAM Dataset: EV_TSGBPQ25BRFVW46X A04001
ROD: EV_TSGBPQ25BRFVW46X.rod
VCID: 1D316F9E0C464DD660-8048
Slave Passenger:
Subsystem 1 - Part No SW: 561 959 812 HW: 561 959 812 Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG_HR 004 4472
Coding: 800000
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 45
Reset counter: 99
Mileage: 116827 km
Date: 2015.08.21
Time: 18:34:36
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Reset counter: 117
Mileage: 116696 km
Time Indication: 0
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 F HW: 7P6 035 730 F
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007660601552
Coding: 0A10040000010110
Shop #: WSC 07346 444 105175
ASAM Dataset: EV_UHVNA A01719
ROD: EV_UHVNA.rod
VCID: 3561973E94B6F59688-8060
End-------------------------(Elapsed Time: 03:47)--------------------------
Gary, I'll keep an eye out at LKQ. I'll probably run out there sometime this week. Are they model year specific as far a style of the lens?2000 Beetle. If anybody has a right rear tail light assy, I'm in the market.
You'll see the rest of the story.
Se ya in Chapin.
