2015 VW CC R-Line. Head light out. PLEASE HELP.
VWCCR-99
Woodridge, IL
2015 Volkswagen CC
Hi, I was driving home from work yesterday and my left headlight went out and the light bulb CEL came on as well. I replaced the D3S HID Xenon by Sylvania. That did not work, so I decided to scan the vehicle, and this is what I got.
Vehicle system control module (09)
Headlamp Range control module (55)
Please let me know if you have any ideas on how to fix this. I drive very early in the morning to get to work so need to fix this as soon as possible.
TurboABA
Kitchener, ON
RIP-2010 Jetta 6spd 2014 Touareg Execline
Swap it to a TDI!
00978 - Lamp for Low Beam; Left (M29): Open or Short to Plus
Possible Symptoms
  • Malfunction Indicator Lamp (MIL) active
Possible Causes
  • Lamp for Low Beam; Left (M29) faulty
  • Wiring/Connector(s) from/to Lamp for Low Beam; Left (M29) faulty
  • Control Module incorrectly coded
Possible Solutions
  • Check Lamp for Low Beam; Left (M29)
  • Check Wiring/Connector(s) from/to Lamp for Low Beam; Left (M29)
  • Check Control Module Coding
VWCCR-99
Woodridge, IL
2015 Volkswagen CC
Yes I tried that, the bulb is good when on the right side of the vehicle, but still not the left. So now I’m wondering if I need to replace the headlight control modules. Or possibly the wiring between the headlight bulb and headlight control module. Not sure what to do at this point if I’m honest.
TurboABA
Kitchener, ON
Wiring, contacts, connectors. Or get VCDS scan to potentially reveal more detail as your tool doesn't give much detail.
Does the high beam work?
Do you have working diagrams?
VWCCR-99
Woodridge, IL
2015 Volkswagen CC
This is what I’ve gotten from VCDS so far. Sorry I got Covid and was unable to reply.
Address 09: Cent. Elect. (J519) Labels:. 3AA-937-087.clb
Part No SW: 3AA 937 087 R HW: 3AA 937 087 R
Component: BCM PQ47 H++ 422 0475
Revision: BD422001
Coding: 0008000000000000008802819400094C20550B0840200D20E484402400C0
Shop #: WSC 05311 000 00001
VCID: 49CF52A3A9BC0D5330F-801C
Subsystem 1 - Part No SW: 3C8 955 119 H HW: 3C8 955 119 H Labels: 1KX-955-119.CLB
Component: WWS464 040215 024 0644
Serial number: 15013006008511
Coding: 044D9D
Subsystem 2 - Part No SW: 5Q0 955 547 A HW: 5Q0 955 547 A Labels: 5Q0-955-547.CLB
Component: RLHS 037 0059
Serial number: S5Y15M03D19H23M37S39
Coding: 0228DD
3 Faults Found:
00059 - Terminal 30 for Interior Lighting
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 1
Fault Frequency: 4
Reset counter: 60
Mileage: 115058 km
Time Indication: 0
Date: 2016.05.27
Time: 17:01:10
Freeze Frame:
Term 15 Off
Voltage: 12.15 V
OFF
ON
OFF
OFF
OFF
00834 - Signal for Activation of Heated Rear Window
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 60
Mileage: 115058 km
Time Indication: 0
Date: 2016.05.27
Time: 17:01:10
Freeze Frame:
Term 15 Off
Voltage: 12.15 V
OFF
ON
OFF
OFF
OFF
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 1
Fault Frequency: 1
Reset counter: 20
Mileage: 115012 km
Time Indication: 0
Date: 2016.05.26
Time: 19:32:09
Freeze Frame:
Term 15 On
Voltage: 14.15 V
ON
ON
ON
OFF
OFF
And
Address 55: Headlight Range (J745) Labels:. 5M0-907-357-V3.clb
Part No SW: 5M0 907 357 F HW: 7L6 907 357 C
Component: AFS-ECU H04 0111
Revision: -------- Serial number: --------------
Coding: 071200010B000400
Shop #: WSC 05311 115 00001
ASAM Dataset: EV_HeadlRegulVWAFSPt 002016
ROD: EV_HeadlRegulVWAFSPt_VW46.rod
VCID: 372B245BCFC88BA356B-8062
Subsystem 1 - Part No SW: 1T0 941 329 HW: 1T0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H06 0007
Coding: 350000
Subsystem 2 - Part No SW: 1T0 941 329 HW: 1T0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H06 0007
Coding: 350000
1 Fault Found:
9574144 - Bulb for Low Beam Headlamp Left
B1217 00 [009] - -
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 23
Reset counter: 33
Mileage: 115162 km
Date: 2022.01.06
Time: 20:06:09
VWCCR-99
Woodridge, IL
2015 Volkswagen CC
Revision: BD422001
Coding: 044D9D
Coding: 0228DD
3 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 4
Reset counter: 60
Mileage: 115058 km
Time Indication: 0
Date: 2016.05.27
Time: 17:01:10
Freeze Frame:
Term 15 Off
Voltage: 12.15 V
OFF
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 60
Mileage: 115058 km
Time Indication: 0
Date: 2016.05.27
Time: 17:01:10
Freeze Frame:
Term 15 Off
Voltage: 12.15 V
OFF
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 20
Mileage: 115012 km
Time Indication: 0
Date: 2016.05.26
Time: 19:32:09
Freeze Frame:
Term 15 On
Voltage: 14.15 V
ON
ON
ON
OFF
OFF
And
Coding: 350000
Coding: 350000
1 Fault Found:
B1217 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 23
Reset counter: 33
Mileage: 115162 km
Date: 2022.01.06
Time: 20:06:09
TurboABA
Kitchener, ON
I've been isolating for 10 days now too, so here's to the VID :sneaky:
Start checking your connections\wiring since you're already tested the bulb.
