NSTDI
Antifreeze boils at 260 when pressurized with a rad cap
The Aux Pump is for the charge air intercooler only. It is a completely separate from the engine coolant system.I'm now convinced my problem is auxiliary water pump. I saw a video on youtube that says the aux pump sends coolant to the egr and heater core. If you get no heat in the passenger compartment when the car is red hot, that's your issue. Also my egr died recently from overheating. So.... I think this is it.
video:
Mine had a lot it at 60 k miles. I'm thinking 30 k may help if you stay with the diesel gate tune and maintain warranty. I believe the EPA did as much as possible to destroy mileage and longevity with the tune because mine ran on regen a lot and my fans would run for 5 minutes after each shutdown. These cars are so much better than electric cars, they needed to get rid of them, and that they did. I changed to a Malone tune with no deletes in December. Both of those issues went away with the new tune and the car is a lot more peppy now. The coolant won't see near as much abuse from the EGR cooler on this tune as well, but the warranty is gone.Has regular flushing been proven to eliminate the crud? How many miles between flushes ?
Did your car have the Pink coolant G12 or violet coolant G13. I have a feeling that the G13 is what causing the Heater core failure as well the issue's you also experienced.Mine had a lot it at 60 k miles. I'm thinking 30 k may help if you stay with the diesel gate tune and maintain warranty. I believe the EPA did as much as possible to destroy mileage and longevity with the tune because mine ran on regen a lot and my fans would run for 5 minutes after each shutdown. These cars are so much better than electric cars, they needed to get rid of them, and that they did. I changed to a Malone tune with no deletes in December. Both of those issues went away with the new tune and the car is a lot more peppy now. The coolant won't see near as much abuse from the EGR cooler on this tune as well, but the warranty is gone.
I also thing a coolant filter like the big rigs now run is a good idea. There is no kit available, but I may rig one up on mine some day. If anyone has done this, I would love to hear about it.
I don't remember what the original fill was,, that is where most of the material accumulated, but I have been using the violet colored coolant since the first failure at 60k miles.Did your car have the Pink coolant G12 or violet coolant G13. I have a feeling that the G13 is what causing the Heater core failure as well the issue's you also experienced.
My car came with G12 from a small TDI dealer who also say to stay away from the G13 crap.
