2015 TDI Coolant Flush?
robahr24
New York
2015 Passat TDI
Adding to my oil leak issues is my coolant. I remember months back, my coolant looked fantastic. The reservoir was clean and I had no sediment inside. About a month ago, my coolant light came on so I topped it up with distilled water. Haven't had an issue since. But I noticed my reservoir was all nasty inside.
It's not running hot and my heater still works great. Was hoping to find a thread on flushing out the system. From what I read about the CVCA engine, is a little different than the previous years. If anybody has a procedure for flushing 2015's out, can you please send it my way. Any other recommendations would be greatly appreciated.
jjblbi
lbi, nj
2014 Passat SEL TDI
Try the search function maybe with "heater core". I remember a pretty good write-up using a shop vac at the filler cap and removing a small hose for the make-up air. When my time comes that's the route I am taking, although I am a 2014 ckra. Good luck, John
steves96tdi
Adamstown, Maryland
1996 Passat TDI 320k, 2015 Passat SEL TDI NOS w/140 mi., 2015 Passat SE TDI 6sp MT, 2014 Passat SE 6sp MT VW Buy Back
