2015 Sportwagen Timing Belt Failure
vdubtc
Jacksonville, FL
2015 VW Sportwagen TDI
First time poster.
2015 TDI Sportwagen lost power at ~40 mph, glow plug lights flashed prior to engine shutting down and unable to restart / turnover. Had the vehicle towed to the dealership and was told engine was catastrophically damaged as the timing belt broke off. 127k miles on the vehicle and planned to replace timing belt at 130k, looks like a pretty expensive mistake to not do it earlier. Vehicle is paid off so I don't have to worry about that.
Quotes from the dealership for a used CRUA with 88k miles around 11k for engine replacement installed and out the door.
Replacement engine (brand new) 17k with labor and fees out the door.
I really enjoy this car and have done all the maintenance up to this point and was planning to keep it for another 5 years or so.
Looking for input or if anyone has any recommendations. Looking to see if I can source an engine myself and have a local shop do the job or if the time / effort required for such a job is worth it. Only downside is if I invest in the replacement, that the emissions equipment will eventually cause follow on repairs and at that point im in over my head on the vehicle in terms of sunken costs.
Standing by for any questions or input if anyone is able to offer advice. Located in Jacksonville, Florida and unfortunately do not have the time to do the swap/repair myself due to work and family obligations.
Here is the part number:
04L-100-033-D
That is for a NEW long block, if one is available. The list I show for that is less than $5400, which seems too cheap to be true. Say 16hr to R&R, plus fluids, etc. I could certainly do it for a lot less, but I'm nowhere near you.
Edit:
No reman CRUAs, all new (I figured that).
Current list price is $5884.15, and the Volkswagen warehouse in Jacksonville has one on the shelf.
So if they are quoting you $17k out the door for a new one installed, I really hope they are at least giving you a reach-around while they have you bent over. I'd probably be able to do that same job for less than $10k.
ticaf
US Mid-Atlantic
Stock 2015 Golf SW S Manual TDI
You might get away with replacing camshaft housing. Search this forum, timing belt failure happened already ( dealer fault though...)
tristan81491
Washington, D.C.
2015 Passat TDI SEL DSG
Yikes. Did you have any other issues that may have contributed to the failure or do you think it can just be chalked up to the age of the belt? I am wondering as my parents have a 2015 Passat TDI with 80K or so on the original belt.
ticaf
US Mid-Atlantic
I'd bet it's a tensioner failure or maybe a water pump failure.
Personally I would do a timing belt kit at 10years regardless of mileage.
vdubtc
Jacksonville, FL
Vehicle was a stop sale so in service date was May of 2017 so figured I’d have a few more miles to make it to 130k. Great recommendation. Will be taking the vehicle to independent mechanic for a more thorough assessment. Turns out dealership didn’t even do a tear down to look at it and just removed the upper toothed belt cover, saw broken belt and stopped there.
whizznbyu
Waxhaw, NC
2015 Golf Sportwagen 6 speed manual. B5 died at 302k miles.
If you find that everyone is more expensive than Oilhammer, consider flatbedding your car to him, have the parts drop shipped to him, fly one way and drive it back. You'd still come out ahead. With the peace of mind that it was done correctly. And your drive back would be a good break in procedure. (No affiliation to Oilhammer)
franklinstower
Kirkland, WA
'15 gsw 6mt wagon
Damn it. This is concerning too me too. I also have a stop sale with an in service date May 2017. I just turned 90,000 miles this week. I was going to ask about the belt replacement at 10 years rather than mileage. But just looked up my maintenance schedule and it is specifically a mileage interval in the manual...Have you tried VWOA about this since you were still technically under mileage for the timing belt service? If a tensioner or water pump failed, might you have a chance at this being a warranty claim?
Nuje
Island near Vancouver
Well, if I ever need a complete engine, rest assured I will be looking there and NOT from VW here in Canada.
**!!SIXTEEN THOUSAND DOLLARS!!**
tdidieselbobny
Stafford,NY (WNY)
Guess I better get mine done when I get the '03 back, I'm at 143k and also was a stop sale purchase in May 2017... I'd love to take it to Anchor Motorworks for the job, but work schedule not gonna be able to. I'll probably have my dealer do it, hoping they find front crank seal leaking and it'll partially be covered under Dieselgate warranty....if not, well ,we'll see:oops:
funoutdoors121
CT (USA)
15 GSW TDI S 6MT (100k miles) and 15 GSW TDI S 6 MT (50k miles)
Hi all!
Planning to get our timing belt replaced shortly on a 2015 GSW TDI S with 98,000 miles, at the same time we get phase 2b done.
So I open up the erWin repair manual covering the engine (D4B80416622-Engine_Mechanical__Fuel_Injection_and_Ignition.pdf) to review the steps needed, and to my surprise it mentions the 2015 has a timing chain, and not a belt!?
Quite confused.
Anyone notice this on the erWin service manual?
Thanks!
gearheadgrrrl
I would argue for coverage under the emissions warranty, VW has programmed these engines to run hot with 100 degree C sustained oil temps common- Those high temps shorten the life of everything in the engine that ain't metal!
Nuje
Quite confused.
I’d advise you to go back and get the proper manual. ;)
No mention of CRUA in the list of engines that are in the manual (D4B80416622) you quoted.
(IOW, you're looking at a manual for gas engines; I believe the "engine" manuals for the TDIs include "glow plugs" in the title.)
funoutdoors121
CT (USA)
Thanks Nuje!
Indeed, seems I downloaded the wrong engine file.
The TDI engine file is D4B8045BD25
Hate to resubscribe at erWin for just that one file but may do so just to have it.
MattRabbit
Orlando, FL, USA
2015 Golf SE TDI, 2014 Beetle TDI, 1981 Rabbit Diesel
I always do my belts a little early. My dad beat it into my head that if the timing belt goes, you're in for a bad day. you can buy a lot of timing belts for the difference in cost of a new engine.
I did mine at 10 years/100K miles. I've got 125K on it now, and assuming I keep the car, I'll do the next one at 200K.
Good luck with the engine repair. If you like the car, I'd probably try to get it fixed, but if not I'd probably sell it for parts and get something else. It'd be nice if Oilhammer lived near all of us!
bmwM5power
Rochester NY
15 GSW TDI S 6MT 02 JETTA TDI GLS 5MT 15 GOLF TDI SE 6MT 15 GOLF TDI SEL DSG
ive got 2 2015 tdis with around 65K mi on both, thinking if need to do this at this point? what do you think?
Nuje
I've got three that I take care of (two for friends), all around 150K km (90K miles).
Speaking with a VW tech, he said he's never seen a timing belt disaster that had failed due to age - it was always mileage. Not saying it's never happened, but that the miles matter more than the years. (And VW doesn't spec a time interval in the manual.)
All that said, 10yrs feels "long enough". So probably will get them done this summer.
Mozambiquer
Versailles Missouri
First time poster.
I just did one for a customer with an engine from Cascade German. They've got Couple in stock still last I heard.
Nuje
You're saying you did a TB on a new engine from CG for someone who waited too long (or too many miles?) on theirs, thus necessitating the new engine?
And kindly mentioning that CG has a couple spare engines available for me if I my roll of the dice comes up snake-eyes....? :D
MattRabbit
Orlando, FL, USA
I did my wife's 2014 Beetle at 48K miles because it was 10 years old. It's not just the belt you have to worry about, it's the water pump, rollers, etc.
pkhoury
That guy with the goats
Medina, TX
2013 JSW, 2 x 2002 Golf, 1995 F450 7.3L
I can't imagine the pump and rollers going bad with age. The belt, yes.
You'd be surprised. With all the used mk4's I've bought over the years, I've seen all kinds of conditions, but the rollers and water pump almost always original.
Mozambiquer
Versailles Missouri
Sorry, I replaced an engine on a 2015 for a customer. It had timing failure..I purchased the long block from Cascade German parts, and they still have more in stock last I knew.
Mozambiquer
Versailles Missouri
Is there any data on how "good" belts look right before breaking?
I've seen a couple that had visible cracks... One was on a 1.8t Passat, it had 230k miles and original belt and water pump. Water pump was bad and leaking, and the belt was super close to breaking...
