Bezra
Hello, I have a pf04 installed in my 2015 Passat TDI SEL.
I took my car to the shop to have a timing belt changed. I asked them to go ahead and swap out the battery too while they had it. I turned the FIS off when I left the car at the shop. When they swapped the battery the FIS must've turned back on. The mechanic hooked up his obd2 scan tool to clear codes and a lot of the systems in the car started failing... Engine died, transmission stuck in gear, esc failure, steering wheel light, and many others...
He called me and I came to the shop. I realized the FIS was still on. I turned it off and some of the failures and dash lights stayed on. I then removed the FIS and the car worked normal and all codes cleared.
A few days later i refreshed the firmware and reinstalled. Car behaved normally but when I tried to go in and adjust visualization parameters I got the following message: Engine ECU not detected contact auto-ploar
I've reached out to auto-ploar and opened a ticket but I haven't heard back yet. Anyone have any ideas?
