2015 Passat TDI polar FIS issues
Bezra
Murfreesboro TN
2002 Jetta TDI, 2015 Passat TDI
Hello, I have a pf04 installed in my 2015 Passat TDI SEL.
I took my car to the shop to have a timing belt changed. I asked them to go ahead and swap out the battery too while they had it. I turned the FIS off when I left the car at the shop. When they swapped the battery the FIS must've turned back on. The mechanic hooked up his obd2 scan tool to clear codes and a lot of the systems in the car started failing... Engine died, transmission stuck in gear, esc failure, steering wheel light, and many others...
He called me and I came to the shop. I realized the FIS was still on. I turned it off and some of the failures and dash lights stayed on. I then removed the FIS and the car worked normal and all codes cleared.
A few days later i refreshed the firmware and reinstalled. Car behaved normally but when I tried to go in and adjust visualization parameters I got the following message: Engine ECU not detected contact auto-ploar
I've reached out to auto-ploar and opened a ticket but I haven't heard back yet. Anyone have any ideas?
lemoncurd
Vancouver, WA | Willimantic, CT
MK6 Jetta SloWagon TDI (Golf Varient)
almost sounds like the polarFIS died during battery connection? idk, perhaps the voltage spike or something got it
i think your best bet would be to wait and see what autopolar has to say
dlhovland
Yakima
2015 golf Tdi manual transmission. Wife's car a 2014 toured v6 Tdi
Took mine out and threw it away. To many problems.
06bluebeetletdi
Middlesex, NC
Sent mine back after the car essentially shut off while pulling out from a stop sign (all lights on dashboard and i could only roll backwards in neutral) never heard from polarfis again (it’s been 2 years). Fun product but catastrophic failure is not good at all. I have a scangauge instead.
x1800MODMY360x
AZ, USA
2013 Passat TDI SEL
Hey, I also have a SG. Do you want some of the values for the passat that I've acquired. As long its a SG2 or SG3.
x1800MODMY360x
AZ, USA
2013 Passat TDI SEL
It’s a scangauge 2, that would be great.
DEF Remaining %
DEF
07E0221ABF
C462851A36BF
3010
003D01F40000
Fuel Gallons level (On xgauge website under Audi 2015)
GAL
07E0221048
C46245103648
3010
0064017B0000
DEF Distance Miles Remaining (On xgauge website under Audi 2015)
DER
07E022322D
C4620532362D
3810
009F00140000
Fuel Temperature F
FTP
07E022162D
04620516062D
3010
00090032FE35
Distance Since Regen
DSR
07E0221156
046205110656
3810
010006490000
Soot Mass Calculated.
SMC
07E022114F
04624511064F
3010
000100010000
