dtreid
New to me 2015 Passat TDI 117000kms
All oil changes done on time and documented at the VW dealer.
Car is burning quite a bit of oil which appears to have started about 70000kms from dealership records. Burning about a quart every 4000kms or so.
Any suggestions as to what the problem could be? Car runs perfect. If I pull the pcv hose off of the valve cover, there is blowby coming out it, but I wouldn't rate it as excessive.
Wondering if it could be bad pcv valve? (Any way to check that without buying a whole new valve cover?)
Car has dieselgate warranty till 2028. Can I get the dealer to fix this problem under warranty?
