93celicaconv
- Joined
- May 22, 2013
- Location
- Wisconsin
- TDI
- Turned in my 2010 Jetta TDI Cup Edition to VW, DSG, Nav, Sunroof / Replaced with a 2015 Passat TDI SEL Premium
Hello. I have a 2015 Passat TDI with the EA288 diesel engine and has 109,000 miles on it now. It has had a very small engine oil leak at the front end for several years, which only showed around the top of the oil pan and on the top of the under engine covers - never dripped to the ground - until just recently now. It is still about 20,000 miles from needing the timing belt change - which when done will likely show exactly the source of the oil leak.
Until then, or until the leak gets worse, does anyone have any previous experience with this engine and a front end oil leak who could advise what the possible source is?
Could it be a crankshaft oil seal? A camshaft oil seal? And oil pump shaft oil seal? Something else?
I believe, when I checked for oil seals, the oil pump does not have a replaceable oil seal - it is rather resolved by replacing the entire oil pump assembly. That seems rather strange, but that is what it appears like to me.
I would just like to get a little background so I'm prepared when I do change the timing belt - so I don't have to order extra parts after finding out the source of the oil leak and having to wait 1-2 weeks to get the parts - I don't want the vehicle to be out of service that long. So if anyone has had a similar experience with their EA288 engine and had the leak repaired, please advise what the source of the oil leak was on yours. Or if you have experience with this family of engines, what the probably causes might be. I would really appreciate it.
