2015 Passat sits too low w/ cargo carrier - what to do?
DivineChaos
Minnesota
mk6 jetta sportwagen tdi
The issue I had with the blue ones is that they're too short and a little loose. The red ones fit much tighter in my springs.
or this way
Nuje
Island near Vancouver
Once you squeeze out all of the air, put one of the little vacuum caps on the nipple so that it stays compressed, otherwise, it wants to spring back to its original shape quickly (drawing in air).
DivineChaos
Minnesota
Thank you very much for the link and other inputs! I just shared it with my local mechanic. I told him estimate an average of 1.5 hours of labor. Let's see what he has to say.
It's easier if the springs are out.
tikal
Southeast Texas
Yes and the shop as the proper lift and safety equipment to do this job.
DivineChaos
Minnesota
The red ones that I selected are slightly taller and slightly wider. They fill the spring. You can see how loose the blue ones are. It still shows a bit of squat. Ones I had there was no squat
tikal
Southeast Texas
Also the Air Lift 1000 Air Suspension Kit 60815 is more readily available than the Firestone one. The brand 'Firestone' also does not give me enough confidence but it might just be my perception.
DivineChaos
Minnesota
I've had both sets. The 1000's are better. My blue ones. The stupid quick connect broke. My red ones had easily 50k miles. And always under pressure.
740GLE
NH
air lift are red, firestones are blue, two different "brands".
tikal
Southeast Texas
I am very thankful for all the suggestions and feedback but I should have done my homework correctly for my 2015 Passat. Today I had an embarrassing moment when I get a call from the shop telling me that the Air Lift 1000 Air Suspension Kit 60815 is the wrong size 🤦‍♂️ 😬 ! So I went to the shop, they put everything back and lowered the car. Now take the measurements of the coil springs. Inside height around 9.5" and inside diameter around 3". I pass the information to the Air Lift customer representative and he recommended the 60902 model:
Air Lift 1000 Universal Air Spring Kit Chart
Kit #Min. Diameter (Y)Max. Length (X)
609003.00″5.50″
609013.00″8.00″
609023.00″9.00″
So the part is coming tomorrow. The other wrong one is already on its way back.
I also talked with the shop owner regarding replacing struts/shocks since the car has already almost 170,000 miles and I want to keep the car for many years. Any recommendations that does not break the bank. Ok, everything is more expensive right now, I realize that. I do not think I can afford the Bilstein HD ones (like $800). What about Sachs or Koni or other brands.
DivineChaos
Minnesota
609003.00″5.50″
609013.00″8.00″
609023.00″9.00″
Thats my bad. That was apparently the ones I just got for my lowering springs .. 60897 looks like the ones I got for oe springs. They were just contacting at normal ride height... Hopefully the company did a free exchange.
tikal
Southeast Texas
No worries. Amazon had no issues taking the previous one back thankfully 👍 The new one (model 60902 is on its way).
I am now researching the strut/shock options/budget to do it all together if possible.
DivineChaos
Minnesota
Your front struts going out? Just buy Sachs and have everything swapped over if their good.
tikal
Southeast Texas
Well I am the third owner of the car as far as I know and struts/shocks are the original with 170K miles on them. I think I would prefer to do the suspension upgrade now that I recently purchased the car and enjoy the ride for seven, eight or more years. I am thinking with installing the Air Lift helper bags it is a good opportunity and be done with it.
DivineChaos
Minnesota
well i purchased coilovers. wish i would have kept the stock rear springs got the ride height. Ive just got lift pucks for the rear so i can get above normal height if i want.
As for coilovers in the front. on the hwy its a firmer yet smoother ride. (i have the rebound set to soft)i have the ecs coil kit. its about an inch lower than stock. the front will get higher than stock, but the rear maxed out is about an inch lower. if you keep stock rear springs that wont be a problem.
tikal
Southeast Texas
Folks, for my 2015 Passat do I need the round spacers in this picture? It is missing in my kit model 60902:
AverageAndy
Phoenix, AZ
2013 Passat
I'm pretty sure the "spacers" are there to protect the airbag from damage, so I would definitely get them for installation.
Nuje
Yeah - the kits I've put in my Mk7 cars, there was a thicker and thinner "spacer" for top and bottom; I wouldn't go through the hassle of installing if it without those in place.
DivineChaos
Minnesota
I
Never used them in mine. But it depends on the height of your bags. That's why I got taller bags than advised for my car. There's already rubber 📔 ng the perches
tikal
Southeast Texas
Thanks for the responses. After spending a considerable amount of time on the phone with Air Lift customer service they told me that the spacers they have are 3.5 inches in diameter and my Passat coil spring inner diameter is 3 inches. Bottom line: I told the shop to install them without any "spacers".
tikal
Southeast Texas
Installation complete! Will post picture(s) once it is loaded fully with the cargo carrier. Pictures shown with 20 lbs of air and new Koni Yellows shocks (thanks IDParts):
DivineChaos
Minnesota
And they ride so much better with weight now
