2015 Passat no defrost
03 shaker
Alabama
2015 Passat SEL
I've searched and can't find a situation exactly like what my car is doing. I've got no air coming through the vents when on defrost. All other settings blow air like normal. I can still hear the fan running when I switch to defrost but absolutely no air comes out the vents at the windshield.
My car is an SEL with the auto climate controls. I've done the blend door recalibration by holding the middle vent button and ac button and no change. I still have great heat on both side of the car so I don't think it would be a clogged heater core. And I have great airflow on all other setting except defrost. Car has about 81k miles. Confused and not sure where to start looking. Any ideas?
03 shaker
Alabama
2015 Passat SEL
Pretty sure that's it. I ran VCDS and sure enough there is a fault code for defrost mode actuator stuck. I didn't realize it had an actuator for every different mode. Hence why the feet and upper vents still worked and changed fine with no defrost. I've ordered the defrost actuator and think that should fix my problem.
TDIx3
US, TN
2015 Passat 2004 LR Disco 2 (x2)
Same problem with mine. Where is the defrost actuator located?
TDIx3
US, TN
Everything works fine, heat is awesome & arrives fast, all modes except defrost work, and have also ran the recalibration.
03 shaker
Alabama
2015 Passat SEL
If you put your head down by the throttle pedal and look up and behind the heater core, it's there. The defrost one is also farther back than the first actuator you see. It was super frustrating for me to change and the smaller and more nimble your hands and fingers are, the better. From reading around this forum and other I think the "easier" way is to remove the dash...but I just started under the dash and ended up getting it changed from under the dash and didn't have to remove it.
TDIx3
US, TN
Smaller & more nimble hands you say. LOL Guess I need to get a shop manual for the tricks to remove the dash then. I will get the codes checked to make sure it’s the same issue first. It was bad when I bought it, & had to drive back to East TN from St Louis through the middle of that crazy winter storm last February. It’s killing me on de-icer right now.
I often take the dash out, and replace all of the stupid Chinese HVAC door motors. They use the same basic garbage ones that GM uses. For some reason, the 2015+ is the worst, by far, so I think that must've been the year they found a cheaper source. Because most all of them I have done are on 2015s or newer. I had a 2018 in here last month with a bad one.
The NMS' dash is not that hard to take out, and you are not removing the HVAC case itself, so the brace and all that stays in place. I remove the seats to make it easier to get the center console out, that really takes the most time I think.
Squelch
Ca
2015 Passat TDI
Anyone have a link or instructions for this actuator job? I will need to do mine soon. Thanks
