Brad95
- Joined
- Aug 9, 2012
- Location
- Arizona
- TDI
- 2013 Passat TDI SE Manual since 09/28/12-04/05/18, 2015 Passat TDI SE Manual Since 03/29/2018
Well other day i had GP Light started flashing on my way to home, but there was no noticeable loss of power. however when i came home, turned off the car and from that day and onward engine started shaking while turning off the car. so did the VCDS Scan and it showed, let me paste it from fault portion of Scan:
2 Faults Found:
5295 - Throttle Valve Actuator Module (J338): Motor Circuit
P2102 00 [032] - Signal Low
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 149656 km
Date: 2022.02.21
Time: 19:02:03
Engine speed: 2234.50 /min
Normed load value: 40.8 %
Vehicle speed: 131 km/h
Coolant temperature: 89 °C
Intake air temperature: 112 °C
Ambient air pressure: 980 mbar
Voltage terminal 30: 14.220 V
Unlearning counter according OBD: 36
Mass airflow sensor 1 bank 1 airflow: raw value: 963.9 mg/stroke
Throttl.valve adapt. 1 bank 1: posit feedback - Spec.value: 0.00 %
Throttl.valve adapt. 1 bank 1: posit feedback - Act.value: 0.00 %
Throttl.valve adapt. 1 bank 1: posit feedback - Offset closed: -0.24 %
Throttle valve adapter 1 bank 1: monitoring - status-Bits 0-7: 0
Throttle valve adapter 1 bank 1: monitoring - status-Bits 0-7: 55
Throttle valve adapter 1 bank 1: monitoring - status-Bits 0-7: 9
Throttle valve adapter 1 bank 1: monitoring - status-Bits 0-7: 66
Throttl.valve adapt. 1 bank 1: posit feedback - Uncnd vlt: 4491.4 mV
5297 - Control Circuit for Throttle Body Module
P3243 00 [032] - Electrical Malfunction
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 149656 km
Date: 2022.02.21
Time: 19:02:05
Engine speed: 2167.00 /min
Normed load value: 0.0 %
Vehicle speed: 126 km/h
Intake air temperature: 108 °C
Voltage terminal 30: 14.260 V
Mass airflow sensor 1 bank 1 airflow: raw value: 407.9 mg/stroke
Throttle valve adapter 1 bank 1: monitoring - status-Bits 0-7: 8
Throttl.valve adapt. 1 bank 1: posit feedback - Uncnd vlt: 4481.8 mV
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 149656 km
Date: 2022.02.21
Time: 19:02:03
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 149656 km
Date: 2022.02.21
Time: 19:02:05
