apexmaster37
Hello
i need some guidance on how to pull out the 3 plastic lines from engine bay which go through chassis and end at back of the car. the three lines are 2 fuel lines, and one ADBlue line. they are together. I have access to ALLDATA but does not give enough information. So far I have disconnected all three lines from inside engine bay, moved the coolant overflow tank to the side. I see the three lines go down into a black plastics tube looking thing in to the chassis rail, then pop back out mid way under the car.
How do I pull them out all the way.
Reason I am doing this is the DEF injector was leaking and VW recommends to replace it, along with the line which goes from it o the ADblue tank.
but i cannot remove just that line. all three need to come out I believe?
