2015 oil pressure switch and limp mode
cobdr
TN
2015 Passat TDI SE
Issue: When the engine is cold (temp qauge less than 80f) it takes very little throttle to cause limp mode and flashing GP light, no other lights. Key off, key on and it’s cleared. Once warm it’s flawless. Each time limp mode is triggered it sets a code for the oil pressure switch. I don’t know the code yet, it still at the shop.
It’s actually at its second shop and each has changed the switch out without change. Both shops are reputable and somewhat stumped at this point. VCDS logging doesn’t show anything out of order. They’re going through the wiring at this point but I’m not hopeful.
A little searching here and I’m nervous about the oil pressure. 1) I read the oil pressure switch doesn’t kick in until 2000 rpm (about when limp mode occurs), and 2) oil pump and hex shaft are potential failure points.
Thing is they oil pressure light never illuminates so I’m not sure it’s an oil pressure problem.
I’m tempted to cover my bases and have the shop replace the pump and hex shaft anyway, one of those better safe than sorry things. Maybe put in a manual gauge as well just for the peace of mind.
Car has 85k miles on it, full delete done around 70k with Malone tune done by the shop that has it now.
Any thoughts, validation or otherwise, are greatly appreciated. I’ll probably be getting it back unsolved if wiring or oil pump don’t work and I’m not sure where to go next.
Thanks,
Bob
DivineChaos
Minnesota
mk6 jetta sportwagen tdi
Thanks,
Bob
Easiest thing is to put an analog pressure Guage on it. Start when cold, and watch. So on a cold motor, when the oil is really thick you get a low pressure fault, but not when it's hot?
And the hex shaft is known for failing....
Well you'll know for certain manually checking oil pressure. Sounds like the pump brive may be slipping when cold. Not sure if that's whats happening. Just my theory..
cobdr
TN
2015 Passat TDI SE
Thanks, I feel like I’m on the right track at least
cobdr
TN
2015 Passat TDI SE
To close this out. We hooked up a mechanical oil pressure gauge and pressure is fine as suspected because the idiot light never came on during this entire event.
Turns out there is a 2nd oil pressure switch that none of the shops (including dealer) were aware of. It’s a little hard for me to fathom that the diagnostic flow didn’t identify it but hey it’s resolved and I’m very glad for that. Especially given the way fuel prices are going right now.
Bob
Taff786
Blackburn
Audi A3
Bob
Hi bob
I’m having the same issue with my car… it’s showing oil pressure switch fault. I believe you said there were two switches?!? Where is the other one? Thanks in advance
cobdr
TN
2015 Passat TDI SE
I’m not 100% sure since the guys at MF Auto did the work. It’s been a while but I recall the tech saying it was hidden from plain site but not hard to access near the upper rear side. The service manager may remember if you give them a call. He drove my car for the best part of a month and we talked a couple times a week during that time. Super nice people and easy to talk to. Black Passat with black and beige interior. If you’re not far from Knoxville stop by their shop, it wasn’t an expensive fix.
I don’t have the car anymore to go snooping around myself. Sorry I couldn’t be of more help.
Bob
740GLE
NH
def will be interesting to see if this crops up as another common issue as the miles pile on.
Ham Mane
Ontario Canada
2015 VW Golf TDI 6MT
Hi wondering if youve had any resolution to this? I have had the same problem getting gradually worse over the last 50k km
Then I would suspect the N428 oil pressure regulation valve. Or something with the oil pump itself, which *could* be a possibility but I would not think it happening on cold operation only.
This valve is in the side of the block, behind the A/C compressor, up against the side of the accessory bracket and the vacuum tube coming from the internal vacuum pump (the vacuum pump is part of the oil pump on the CVCA, like it is on the V6 TDIs).
Variable oil pressure regulation.... yet another useless addition to the EA288 TDIs that the earlier cars didn't have. Many of the VAG gassers have used this type setup for years, so we already know they are troublesome. Shocker, the diesels are no different.
