2015 jetta tdi dpf sensor replacement
kefuller
Myrtle Beach, SC 29588, USA
2015 Jetta SE
Anyone replaced this sensor? My scanner said it was the DPF sensor, I found a similar set of sensors under some heat shield with snap buttons on top of the engine under the plastic cover. But the part numbers are different than the one i bought at the dealer. Any help would be appreciated.
Dannyboy
Mb
Sometimes the numbers will be different if the part is superseded or the same part for different vehicle.
Usually the last 3 numbers should be the same just a letter added to the end.
Example
03L 906 051 D
076 906 051 B
03G 906 051 A
07Z 906 051 A
They are all the same part with a couple of updated parts
Dannyboy
Mb
The letter on the end is revision/mod code. I believe D is the latest revision.
