2015 Jetta Sedan TSI needs complete maintenance check
ccaissie
Lincoln County, Maine
2002 Jetta TDI, 99.5 GL Gasser, 1989 jetta diesel n.a.
Planning to go through this car and get it on the track for a long life. It was a Dealer lease car and I got it with 40,000 miles on it, Now 43,000.
Where do I find a maintenance schedule for the 40,000 mile interval. What do you consider essential to check out at this mileage AND AGE?
It needs front springs replaced and rear rotors and pads...other than that it's a perfect car.
forrest resto`s
athens ga.
2000 jetta tdi auto rc2 2013 passat tdi 2015 passat tdi auto 2011 jetta tdi nav. s'roof..man. dpf delete 1970 GTO JUDGE 520 HP
Hey.. this is the TDI (diesel) forums..might want to post in the vw tsi (gas) forums
There are two TSI engines that could be in a 2015 Jetta sedan, the CPKA and the CPRA (both 1.8L). However both should have the same PM schedule.
40k is an oil change, a tire rotation, and cabin filter. Brake fluid every 2-3 years.
The water pump assembly could fail at any moment. Make sure the crankcase stays full (502.00 5w40).
