2015 highline BCM upgrade in non-GLI Jetta 2013 TDI?
kylesobrien
Montreal, Quebec
VW Jetta 2013 TDI
I've been lurking around the forums for a few years, but after a few desperate days of searching, I've decided to submit my first post -- greetings!
I recently installed an MIB2 Discover Media head unit (component protection deactivated) in my 2013 Jetta TDI. Navigation works, the radio works, but my microphone is not working. I believe this issue can be sorted out with a kit from EZT. However, I also bought a newer CAN gateway to avoid lag, and enable me to interact/scan the radio with VCDS, potentially install a backup camera later, etc.
It seems I was foolish, as the CAN bus gateway appears to be integrated into the BCM on lowline North American Jettas of this era... The questions I was hoping to ask here:
- can I upgrade my original 2013 BCM (5C0 937 087 A) to a 2015 Jetta highline BCM (such as 7H0 937 090 E)?
- would this upgrade make it possible to install a lowline reverse camera kit?
- would this BCM recognize the MIB2 unit properly, and allow me to interact with it via VCDS (currently, I see fault codes for the radio and telephone modules)?
- does this swap require a dealer visit, or a garage with ODIS access to sort out component protection issues?
Thanks in advance for any suggestions or advice -- if this is just a really terrible idea, feel free to tell me, I won't take it personally.
Cuzoe
Los Angeles
MK7 Golf S
Oh man... I know nothing about PQ35 (is that correct?) platform. @Nuje may know something, but I've only done retrofits on my MQB.
kylesobrien
Montreal, Quebec
VW Jetta 2013 TDI
Thanks for jumping in, @Cuzoe.
I might be mistaken, but I think the non-GLI Jettas of my car's era are actually PQ25, not PQ35 -- mentioned on the RossTech page here:
VW Jetta (16) Body Control Module - Ross-Tech Wiki
... and also on this TDIClub thread I just found here:
Full mfd upgrade | TDIClub Forums
If I understand correctly, physically, they're Jetta sedans, but the electronics seem to have more in common with Polos than Passats.
Last night I found a blog post that seems to summarize the removal/install -- it's in Portuguese and English (scroll down). This guy was working with a PQ35 Jetta, but I suspect the process/coding is similar:
I think it's doable, at least. It looks like the odometer data is stored in the cluster and ECU, so that's good, won't cause issues there.
My current cable is a Micro-CAN, which I don't think will read extended coding on newer modules (like the MIB2 unit), so even if I do this I will probably need to upgrade to a HEX-V2 or similarly new interface. A bit of a gamble but at least I see evidence I'm not the first to try.
kylesobrien
Montreal, Quebec
VW Jetta 2013 TDI
@vito3223 Sorry for bugging you, but I believe you upgraded your Jetta cluster many years ago, curious if you have any thoughts on swapping a newer PQ25 BCM into my TDI which will properly recognize an MIB2 radio.
pedroYUL
MI, USA
2004 wagon BEW; 2015 Passat CVCA; 2015 GSW CRUA
I'm not 100% sure, but I suspect you will need ODIS (or hack the MIB2) to get rid of Component Protection.
The way I understand it works is, CP is a handshake between whatever it is, say MIB2, and the gateway. Either of the 2 not talking and it triggers CP in both the gateway and the component.
If you replace the gateway, then all the handshakes need to be reestablished: MIB, BCM...
You can hack some brands of MIB2 yourself, info was published in the mk7golf site. But you need a few gadgets and lots of reading.
kylesobrien
Montreal, Quebec
VW Jetta 2013 TDI
A brief update, I found a Ross-Tech post including an autoscan log where the Jetta owner has the same BCM I mention above, with integrated CAN gateway, and it includes address 5F (the MIB2) with a summary of all the current adaptations.
The same poster has both park distance control and a reverse camera installed:
OPS control overlay not auto-hiding on MIB Discover Media (2015 Jetta) | Ross-Tech Forums
I purchased a new "old stock" BCM (7H0 937 090E) which I'm going to have installed, this should do the trick; can post a quick update assuming I'm successful. Thanks to everyone for the help, really appreciated.
