Tdimrtwo
My 2015 GSW has consumed about 1qt of oil between 10k oil changes pretty much since new. Now 255k miles on the clock, and it’s using more oil, over two quarts between oil changes. I know this isn’t excessive on a car with this many miles, but i’d really like to identify the cause and cut down on oil usage, if possible. Three potential problems come to mind:
1. Worn out turbocharger
2. Stuck piston oil ring
3. Worn out valve guides
Any other likely culprits? How can I check to see what’s causing the oil consumption?
