So I just installed a new Curt trailer lights wiring harness into my MKVII 2015 Golf Sportwagon. I'd read all thru this thread and wow, a lot of complicated stuff to get the lights to work. I didn't do ANY of that. I got the Multi-function taillight converter (from torklift central, ordered it when I ordered my eco-hitch). Followed the included install directions, they worked fine. In the end here is how I have the wires from the taillights wired:
Converter box Left turn signal wire goes to the Drivers side black with red stripe wire.
Converter box Right turn signal wire goes to the Passenger side black with green stripe wire (the smaller hatch near the taillight on the passenger side, ran the wire under the plastic trim that goes across the back of the hatch).
Converter box Tail lights signal wire goes to the Drivers side gray with black stripe wire.
Converter box Brake signal wire not used, goes to chassis ground.
Converter box Hot (power) wire goes to the 12 gauge wire I ran from the interior fuse box (could have ran it from the engine compartment fuse box but I ended up running my power-wire inside the car just inside the doors under all the plastic trim, goes up and over the rear tire inside the panel (instead of underneath the car), and my converter box is located inside the Drivers side rear access panel near the taillight).
Converter box Ground wire goes to chassis ground (self tapping screw used, hole near the converter box in the upper right corner of the hatch).
Converter box 4-wire flat trailer-lights-connector follows the Passenger side Turn signal wire from the Drivers side hatch, but instead of running clear across to the Passenger side it drops down thru the metal thru a rounded-ends rectangular hole, and below that is another identical hole that has a plastic plug installed, removed the plug and dropped the connector thru that 2nd hole and outside the car, where it comes down inside the plastic rear bumper trim. Have the connector mounted on a 4-pin flat connector specific L-bracket, which is attached to the underside of the rear-bumper plastic just to the left of the hitch.
Note: I didn't want my converter box to be powered all the time even tho I don't have a trailer attached (as any towing a trailer will be few and far between...don't even have a trailer yet).
So, wanting to be able to turn my trailer lights harness off when I don't have a trailer hooked up (and also know when they are 'ON') my 12 ga power wire runs from inside the fuse box near the driver door to the right under the steering column, and goes to a lighted 12v 30 amp "Trailer light power" switch that I have mounted in a little home-made box that attaches just to the right of the steering-wheel column on the outside of the plastic panel (I made it this way so that in the future it's easily removable, as I didn't want to drill holes in the plastic trim panel that goes from the drivers door to the center console under the steering column).
The wire from the fuse box to the switch is fused for 15amps (came with the harness kit).
The switch has 3 connectors: 1 for incoming power, 1 for outgoing power (load) and 1 that goes to chassis ground which is how the switch 'ON' light works (when the switch is turned ON, the switch light draws a small bit of power off the incoming power, goes thru the switch bulb to light it, and then to ground...the rest of the power goes out the 'load' terminal to power the converter box). And finally, the long length of the power wire runs from the switch 'load' terminal to the converter box 'Power' wire.
All was tested using a 4-pin flat trailer light test unit ($6 on Amazon). The test unit has 3 LED's: Left turn signal, Right turn signal, and Tail-lights.
Here are the testing results (all with the ignition on/engine running):
Left turn signal active, car shows left signal flashing, tester shows left turn LED flashing.
Right turn signal active, car shows right turn signal flashing, tester shows right turn LED flashing.
Tail-lights active (headlights on), car shows both tail-lights active and tester shows Tail-light LED active (tail-lights are dimmer than turn signals).
Brakes activated, car shows both brake lights active, tester shows both left and right turn LED's active (solid on).
Emergency flashers activated, car shows both turn-signal lights flashing together, tester shows both left and right turn Led's flashing together.
And that is that. Now I just need a trailer!
