Nuje
- Joined
- Feb 11, 2005
- Location
- Island near Vancouver
- TDI
- 2015 Sportwagen; Golf GLS 2002 (swap from 2L gas); 2016 A3 e-tron
Sounds good - thanks for the tip; I'll be sure to give it a try.
My crank position sensor's voltage was way off compared to the new one that was put in. Vcds did not log the difference. Since changing it, my starts have been 100 percent normal. That being said, I am not in the warm humid weather anymore either. So who knows.My mechanic says that golf 7 is a new generation car with lots of sensors and if they are no good, vcds shuld give you an error. Says also that fuel pressure in my case is not a problem cos if the fuel pump (the one under the rear seat) had sth wrong with the pressure. vcds should give that message na vcds. furthermore, he clames that we should seek the problem with either leakage fuel , or fuel goes back to the tank, or even there is sth wrong with the current which cannot give enought curent fot the starter to 'fire up' the engine. No blind replacing pparts he dadvices as it will drain our pockets and may not solve the problem.
No idea what to think of that.
For me, the problem is just an annoyance. Eventually, I will try and log crank position sensor signal and see if there is anything out of place, like in the thread I quoted.pedroYUL
So what is your nest step? Are you going to do (if so what?) to eleminate the problem?
Mine does not work like that, regardless of the outside temperature, if I push down the clutch and press the start button it cranks immediately and does not wait for the glow plug light to go out. Perhaps its just my model, 2016 GTD with EA288 engine.When you say "you should...." is that a known "best practice" or in the manual or something?
The way push-button start works in my car is that it won't crank the engine until the glow plugs have finished glowing. So if it's 0°C outside, if I push in clutch/brake and hit START right away, the car waits a good 3-4sec or whatever while the glow plugs do their thing, then cranks. And even if I let go of the START button right away, the car keeps cranking. In warm weather even, there's still a slight pause after hitting the button.
(This messed with me a bit working on a Mk6 a while ago....couldn't figure out why the car wouldn't start: The engine would start to crank then immediately stop .
Took me a couple of tries to realize that push-button start was more like turning the key in a traditional car - the car cranks as long as the button is pushed, but stops as soon as you let go of it).
I had the exact same issue and replacing the crank position sensor seems to have fixed the problem...Long crank problem on first start of the day started this summer on my 2015 GSW. Pushing the start button without stepping on the brake for a while has been a good work-around. Once the weather got colder, the long crank prob disappeared only to return in the last couple of days when the nights have not been as cold. I'm in agreement with R's mechanic that outside temp might have something to do with the problem and I'm wondering if it is possible to raise the temp at which the glo plugs turn on from 40F, or whatever the OEM setting is, to maybe 60F. I've got a friend with a VAG-Com and would appreciate any input on where and how to change this setting
After my cps was changed it did a really ****ty start the next day. Was flawless after. I think the computer was learning the new sensor. Has been fine since.I replaced camshafte sensor for a new one. The problem, at first apeared the next day after the replacement. Next day was good no crank. My friend who ownes mk7 adviced me to turn the lights to zero position as a have coming/leaving home on. In the mornig light sensor turns on my lights. So said try to start engine only on zero position. I has been no long crank for 5 days now. No idea for how long. But strange. During te samer (new battery fitted at the end od may 2022) no light were turned on in the mornig and long crank in the morning appeared.
Just so I am aware, the crank position sensor and the cam sensor are two different parts right?I'll give you the feedback if long crank in the morning still persists or not. I bought cps from official porshe, audi, VW dealer it was discunted but on the package was exp date september 2021. Isn't it strange ?
Autopart manufacturer I guess it may not be reliable but I don't know.
To sum up. I believe that the starte gets too little current to 'swing' camshaft hence it (cps) is lazy to 'run' right away together with crankshaf
Rear main seal area, tone wheel and crank pos sensorJust so I am aware, the crank position sensor and the cam sensor are two different parts right?
I replaced the crank position sensor in my 2013 Audi A3 TDI
