Hello I'm still struggling with a long crank after night (ea288)
. I've noticed that the intake air temperature sensor works strangely. I attached a photo with graph. In the graph, when the engine is idling, the sensor measures temperature correctly. But when the engine is turned off and the ignition is turned on again, the temperature rises up to 150 degrees celsius,when engine starts again the temperature drops to -5 and then returns to normal +8 degrees celsius. Maybe you can check if this is the case with you. The outdoor temperature was +5.
postimg.cc
