2015 Audi Q7 TDI "Brake Pads!" Light Trouble Shooting
Mozambiquer
Versailles Missouri
If you look at the Google photos above I disabled it in the instrument cluster to go no avail
Its really hard to see with the potato photos, but it looks like it's still enabled there.
Mozambiquer
Versailles Missouri
Other guy could see it but yes my laptop screen is broken sadly it is Infact disabled
Did you then transfer that coding to the control unit? The long coding helper only calculates the code to put into the section for coding. If you didn't do that then it wont program it. I just did the same on my Q7 one min ago. You go to the long coding, uncheck the bit 10 brake wear warning, then you you copy the coding above that and paste it into the line for new coding and click "do it!" and then it will code it. I also did the gear signal display on the TCM on mine so I can see which gear its in.
Carter79
Regina, Saskatchewan, Canada
2015 Audi Q7 Vorsprung
Yes I clicked do it and still nothing I'm rather sad haha hoped I could fix it myself
Mozambiquer
Versailles Missouri
Did you copy the code from the long coding helper and then paste it on the coding page and then click do it? Then did it give you the message "coding accepted"?
Carter79
I dont think that has any relation cause if it was low/failed then it would have a red warning saying brake level low or something along those lines. Very surprised that since its unchecked that its still showing up.
Incase you wanted an update the shop diagnosed they are "90% sure" that its the harness that corroded to it 7L0971279F and I'd need to replace that whole thing. What do you think?
Mozambiquer
Versailles Missouri
If it were the harness, coding it off in the cluster should still turn it off.
Mozambiquer
Versailles Missouri
And why wouldn't the VCDS pick this error up on the sensor search?
I still suspect that for some reason the coding isn't taking. What is the current coding on yours and then I can calculate the options which are selected.
Carter79
I will check in the next hour here. Also looking at the wiring diagram would not looping just the front left brake wear sensor remove that light? As it's the start of the circuit for the brake wear sensors.
Mozambiquer
Versailles Missouri
Yes, but if its the harness that won't fix it.
Carter79
NEW VCDS SCAN
Code:
Thursday,28,December,2023,18:02:05:58049
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 23.11.0.0 (x64)  HEX-V2 CB: 0.4643.4
Data version: 20231027 DS351.0
www.Ross-Tech.com
VIN: WA1WMCFE8FD025145   License Plate:
Mileage: 176670km-109777mi   Repair Order:
Chassis Type: FE-AU56 (4F0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 28 36 3C 42 46 47 4C 4F 52
          55 56 5C 5F 62 69 6C 6D 6F 72
VIN: WA1WMCFE8FD025145   Mileage: 176670km-109777miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
28-HVAC, Rear -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4C-Tire Pressure II -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5C-Lane Maintain. -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
6F-Centr. Conv. II -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CNRB)       Labels:. 059-907-401-V2.clb
   Part No SW: 4L2 910 401 A    HW: 4L0 907 401 E
   Component: 3.0TDI FSA    X23 0014
   Revision: 54X23---    Serial number:                CVN: FE04CE5E38D3FF8238D3FF820E1FC39E
   Coding: 2A2A4012253600050000
   Shop #: WSC 23116 035 00000
   ASAM Dataset: EV_ECM30TDI0114L2910401A 001015
   ROD: EV_ECM30TDI0114L2910401A.rod
   VCID: 221DE4BD9441DD0A197-8076
   VINID: 9D106775359521650008504414176DCD86
No fault code found.
Readiness: 0 0 0 1 X
Address 02: Auto Trans (J217)       Labels:| 0C8-927-7XX-V1.clb
   Part No SW: 0C8 927 750 AQ    HW: 0C8 927 750 AQ
   Component: AL1000 AISIN  002 3399
   Serial number:                CVN: D12703D3
   Coding: 001378
   Shop #: WSC 03823 004 1048576
   ASAM Dataset: EV_TCMAL991031 002115
   ROD: EV_TCMAL991031_002_AU56.rod
   VCID: 7BA3F9D9536B4CC27A1-802E
Address 03: ABS Brakes        Labels:. 4L0-910-517-V2.clb
   Part No SW: 4L0 910 517 M    HW: 4L0 614 517 L
   Component: ESP ALLRAD MK25E1   0020
   Revision: 00H02001
   Coding: 0099441
   Shop #: WSC 31414 790 00001
   VCID: 343112E5323543BAFBB-8060
Address 05: Acc/Start Auth.        Labels:. 4F0-910-852.clb
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 H
   Component: FBSAUDIC6 ELV   H08 0210
   Revision: 00H08000    Serial number: 10603902203566
   Coding: 0000135
   Shop #: WSC 16540 005 1048576
   VCID: 2517FFA189EF2A327C5-8070
   Subsystem 1 - Part No: 4F0 910 132 L
   Component: FBSAUDIC6 EZS   H05 0020
   Subsystem 2 - Part No: 4F0 910 335 B
   Component: FBSAUDIC6 KSG   H03 0020
2 Faults Found:
00191 - Passenger's Door Handle Touch Sensor (G416)
            007 - Short to Ground
             Freeze Frame:
                    Fault Status: 01110111
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 250
                    Mileage: 176302 km
                    Time Indication: 0
                    Date: 2023.12.22
                    Time: 09:43:46
00192 - Rear Left Door Handle Touch Sensor (G417)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 5
                    Reset counter: 0
                    Mileage: 176302 km
                    Time Indication: 0
                    Date: 2023.12.22
                    Time: 09:43:46
Address 08: Auto HVAC (J255)       Labels: 4L0-910-043.clb
   Part No SW: 4L0 910 043 D    HW: 4L0 820 043 AQ
   Component: KLIMA 4 ZONEN H15 0070
   Revision: 00---031    Serial number: 00000000473615
   Coding: 0304A036
   VCID: 2517FFA185EF2A327C5-8070
   Subsystem 1 - Part No SW: 8K0 959 772 F    HW: 8K0 959 772
   Component: SLR-B8  H06 0007
   Serial number:           0142582083
   Coding: 070000
1 Fault Found:
00819 - High Pressure Sensor (G65)
            002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 36
                    Mileage: 176305 km
                    Time Indication: 0
                    Date: 2023.12.22
                    Time: 15:02:28
             Freeze Frame:
                    Temperature: 45.0 C
                    Temperature: 12.0 C
                    Load: 20.0 %
                    Temperature: -55.0 C
                    RPM: 840 /min
                    Absolute Pres.: 1.0 bar
                    Current: 0.010 A
                    Temperature: 8.0 C
Address 09: Cent. Elect.        Labels: 4F0-910-279.lbl
   Part No SW: 4F0 910 279 AG    HW: 4F0 907 279 C
   Component: ILM Fahrer      H31 0400
   Revision: 00000000    Serial number: 4F0907279
   Coding: 0133114
   VCID: 6E85C08D1C99296ACDF-803A
   Subsystem 1 - Part No: 4L1 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AU716   H18 0110
   Coding: 00064792
   Shop #: WSC 31414
   Subsystem 2 - Part No: 8K0 910 557   Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH04 0003
   Coding: 00152619
   Shop #: WSC 31414
Address 10: Park/Steer Assist (J446)       Labels:| 4L0-919-475-7X2.clb
   Part No SW: 4L0 919 475 A    HW: 4H0 919 475 C
   Component: PARKHILFE 8K  H07 0011
   Revision: 11001001    Serial number: 55931509701541
   Coding: 29011F
   ASAM Dataset: EV_EPHVA18AU7160000 001001
   ROD: EV_EPHVA18AU7160000.rod
   VCID: 343112E53EB543BAFBB-8060
Address 15: Airbags        Labels: 4L0-910-655.clb
   Part No SW: 4L0 910 655 A    HW: 4L0 959 655 B
   Component: 75 AIRBAG AUDI8RH45 0230
   Revision: 09H45000    Serial number: 0038QD90TFS2
   Coding: 0014133
   VCID: 2B030999EF0B1C42AA1-807E
   Subsystem 1 - Serial number: 6332QSME5F533E46U
   Subsystem 2 - Serial number: 6342QSME0B534746G
   Subsystem 3 - Serial number: 6352QSME56534844G
   Subsystem 4 - Serial number: 6362QSME5F532576Q
   Subsystem 5 - Serial number: 63734SME3F534D427
   Subsystem 6 - Serial number: 63834SME3C533F78F
Address 16: Steering wheel        Labels: 4F0-910-549.lbl
   Part No SW: 4F0 910 549 B    HW: 4F0 953 549 F
   Component: J0527               0830
   Revision: 00H09000    Serial number: 90026150770199
   Coding: 0032342
   VCID: 2809F695FEFD375A473-807C
   Subsystem 1 - Part No: XXXXXXXXXXX
   Component: E0221           H03 0040
Address 17: Instruments (J285)       Labels:. 4L0-920-xxx-17.clb
   Part No SW: 4L0 920 933 G    HW: 4L0 920 933 G
   Component: KOMBIINSTR.   H35 0332
   Revision: 00000000    Serial number: X2I03AL4G
   Coding: 03D7640409000008020304
   VCID: 313F1BF1C127769290D-8064
Address 19: CAN Gateway (J533)       Labels:. 4F0-907-468.clb
   Part No SW: 4F0 907 468 S    HW: 4F0 907 468 G
   Component: GW-BEM 5CAN-M H06 0058
   Revision: MB800038    Serial number: 3800M1540104DF
   Coding: 00C303
   VCID: 3FDB4DC9077390E2169-806A
   Subsystem 1 - Part No SW: 8K0 915 181 D    HW: 8K0 915 181 D
   Component: J367-BDM  H07 0125
   Serial number: 42103I58254121849818
Address 28: HVAC, Rear        Labels: None
   Part No SW: 4L0 910 158     HW: 4L0 919 158 AE
   Component: KLIMABETAETIGUNGH06 0060
   Revision: 00---012    Serial number: 00000030382610
   Coding: 0000006
   VCID: 6889B6953E7DF75A873-803C
1 Fault Found:
01320 - Control Module for Climatronic (J255)
            013 - Check DTC Memory
             Freeze Frame:
                    Fault Status: 01101101
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 250
                    Mileage: 176305 km
                    Time Indication: 0
                    Date: 2023.12.22
                    Time: 15:02:33
             Freeze Frame:
                        ON
Address 36: Seat Mem. Drvr (J136)       Labels: None
   Part No SW: 4F0 959 760 D    HW: 4F0 959 760 D
   Component: MEM-FS        H08 0065
   Revision: AA000000    Serial number: 00000142898018
   Coding: 00581B00000011110000
   VCID: 323D14FDC4214D8AE97-8066
Address 3C: Lane Change        Labels: None
   Part No SW: 4L0 910 566 C    HW: 4L0 907 566 B
   Component: J0769_SWA_MasterH03 0050
   Revision: 00H03000    Serial number: 6PZ 009 014-10
   Coding: 0010001
   VCID: 2E05008DDC19696A8DF-807A
   Subsystem 1 - Part No: 4L0 910 568 C
   Component: J0770_SWA_Slave_H03 0050
   Subsystem 2 - Serial number: 6PZ 009 014-30
   Subsystem 3 - Serial number: 5F11.04.1500H03000AMS13006
   Subsystem 4 - Serial number: S13006
Address 42: Door Elect, Driver (J386)       Labels:. 4F0-959-793.clb
   Part No SW: 4F0 959 793 T    HW: 8K0 959 793 M
   Component: TSG FA        H12 0362
   Revision:             Serial number: 0000146745243
   Coding: 011F57205E40440004
   VCID: 48C9561552BDD75AA73-801C
Address 46: Central Conv.        Labels:. 4L0-910-289.lbl
   Part No SW: 4L0 910 289 K    HW: 4L0 907 289 K
   Component: Komfortgeraet   H12 0130
   Revision: 0130 ---    Serial number: 82010021830000
   Coding: 3569949
   VCID: 382926D52E5DA7DAD73-806C
   Subsystem 1 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H05 1501
Address 47: Sound System (J525)       Labels: None
   Part No SW: 4L0 035 223 J    HW: 4L0 035 223 G
   Component: BOSE G3 Q7    H04 0160
   Revision: CH004001    Serial number: 00000000083026
   Coding: 030000
   VCID: 290FF391E9F70E5258D-807C
Address 4C: Tire Pressure II        Labels: 4F0-910-274.clb
   Part No SW: 4F0 910 274 B    HW: 4F0 907 274
   Component: J793  RKA+      H04 0110
   Revision: 00000519    Serial number: 00005191098848
   Coding: 0758473
   VCID: 2313E1B987DBD402121-8076
Address 4F: Centr. Electr. II        Labels: 4F0-910-280.lbl
   Part No SW: 4F0 910 280     HW: 4F0 907 280 D
   Component: ILM Beifahrer   H17 0100
   Revision:             Serial number: 00000000229431
   Coding: 0012001
   VCID: 5EE5904DEC39B9EA7DF-800A
Address 52: Door Elect, Pass. (J387)       Labels:. 4F0-959-792.clb
   Part No SW: 4F0 959 792 T    HW: 8K0 959 792 M
   Component: TSG BF        H12 0362
   Revision:             Serial number: 0000146772372
   VCID: 47CB55295FA3D822AE9-8012
1 Fault Found:
02126 - Central Locking Button; Exterior Door Handle
            008 - Implausible Signal
             Freeze Frame:
                    Fault Status: 01101000
                    Fault Priority: 3
                    Fault Frequency: 68
                    Reset counter: 0
                    Mileage: 176302 km
                    Time Indication: 0
                    Date: 2023.12.22
                    Time: 09:32:40
Address 55: Headlight Range        Labels: 4F0-910-357.lbl
   Part No SW: 4L0 910 357 B    HW: 4L0 907 357 B
   Component: AFS 1           H01 0010
   Revision: 00000001    Serial number:
   Coding: 0000031
   Subsystem 1 - Part No: 7L6 941 329 A
   Component: AFS-Modul links H07 0004
   Subsystem 2 - Part No: 7L6 941 329 A
   Component: AFS-Modul rechtsH07 0004
Address 56: Radio (R)       Labels:. 4F0-035-0xx-56.clb
   Part No SW: 4G0 035 082 G    HW: 4G0 035 082
   Component: Radio U SIRIU H66 0133
   Revision: AB001007    Serial number: 156D/0F8253366
   Coding: 020007010000000000
   VCID: 2411E2A58ED5D33A6BB-8070
Address 5C: Lane Maintain.        Labels: None
   Part No SW: 4E0 910 217 D    HW: 4E0 907 217 C
   Component: J759  LDW       H08 0010
   Revision: 00H08023    Serial number: 3002154080003F
   Coding: 0000007
   VCID: 211FEBB19DC7C61200D-8074
Address 5F: Information Electr. (J794)       Labels:. 4E0-035-6xx-5F.clb
   Part No SW: 4L2 035 664 G    HW: 4L2 035 664 G
   Component: H-BN-NA       H42 0901
   Revision: --------    Serial number: 512D.0F7503982
   Coding: 180200060004E3EF590023456F632003F40000020100000000
   Subsystem 1 - Part No: 8R0 060 884 CJ
   Component: NAR 2015  1102
   Subsystem 2 - Part No SW: 8R0 919 604 A    HW: 8R0 919 604 A
   Component: DU7 High  H42 0104
   Serial number: A130DJ0F3327401
   Subsystem 3 - Part No SW: 4L0 919 614 C    HW: 4L0 919 614 C
   Component: E0380 Bedient  H01 0060
   Serial number: 00000002245453
   Subsystem 4 - Part No: 8R0 060 961 G
   Component: CD-Database  5950
1 Fault Found:
03157 - Functionality limited due to Communications Disruption
            000 - - - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 176679 km
                    Time Indication: 0
                    Date: 2023.12.28
                    Time: 17:59:55
             Freeze Frame:
                    Bin. Bits: 00000000 00000010
                    Bin. Bits: 00000000 00000000
Address 62: Door, Rear Left (J388)       Labels:. 4F0-959-795.clb
   Part No SW: 4F0 959 795 P    HW: 4F0 959 795 P
   Component: TSG HL        H11 0362
   Revision:             Serial number: 0000146782946
   Coding: 010E57204040230004
   VCID: 46D5582D58A9C12A55F-8012
Address 69: Trailer (J345)       Labels:. 4E0-907-383.clb
   Part No SW: 4E0 907 383 J    HW: 4E0 907 383 J
   Component: Anhaenger     H12 0100
   Revision: 2A001001    Serial number: 00000366446102
   Coding: 0200000000000000
Address 6C: Back-up Cam. (J928)       Labels:* None
   Part No SW: 4L0 907 428     HW: 7P6 907 441 D
   Component: TopView       H05 0293
   Revision: 11001001    Serial number: 82330JF0221357
   Coding: 020C010001000100010102000000
   ASAM Dataset: EV_CamSysteCorneViewAUDI 004005
   ROD: EV_CamSysteCorneViewAUDI.rod
   VCID: 6E85C08D1019296ACDF-803A
Address 6D: Trunk Elect.        Labels: 4L0-910-945.clb
   Part No SW: 4L0 910 945     HW: 4L0 827 851 F
   Component: ValeoHeckdeckel H58 0500
   Revision: --H58001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   VCID: 6C81CA852A85DB7AE3B-8038
   Subsystem 1 - Part No: 4L0 910 946
   Subsystem 2 - Serial number: 9.
   Subsystem 3 - Serial number: RD13.04.15--H58001002G0038
   Subsystem 4 - Serial number: 2G0038
Address 6F: Centr. Conv. II        Labels:. 4L0-910-290.lbl
   Part No SW: 4L0 910 290 A    HW: 4L0 907 290 A
   Component: ILM HINTEN 2    H08 0080
   Revision: AAH08080    Serial number: 0146620530----
   Coding: 0003595
   VCID: 2615F8ADF4E9212A75F-8072
   Subsystem 1 - Part No: 4L0 910 591 A
   Component: J_245_EE16_SKB10H15 0220
   Subsystem 2 - Part No: 4L0 910 591 A
   Component: J_394_EE16_SKB10H15 0220
   Subsystem 3 - Part No: 4L0 910 591 A
   Component: J_392_EE16_SKB10H15 0220
1 Fault Found:
01514 - Regulator for Roof
            012 - Electrical Fault in Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101100
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 176679 km
                    Time Indication: 0
                    Date: 2023.12.28
                    Time: 18:00:06
Address 72: Door, Rear Right (J389)       Labels:. 4F0-959-795.clb
   Component: TSG HR        H11 0362
   Revision:             Serial number: 0000146805990
End----------(Elapsed Time: 02:11, VBatt start/end: 12.5V/12.5V)-----------
LONG CODING WHILE SCANNED (BYTE 10 BIT 0 DESELECTED) "03D7640409000008020304"
NEW LONG CODING (BYTE 10 BIT 0 SELECTED) "03D7640409000008020305"
MrCypherr
Ontario
Mk6 Wagon
If you looped it and its still not working, and the coding is applied as you said, then it should be gone. Regardless if the harness is crappy, you coding it out of the system, it should go away. Because the car should think that it doesnt have that feature. I agree with mozambiquer, I feel like the coding isnt talking/applying correctly.
Carter79
Okay well here is the final update! So regardless of this damn code taking or not taking sadly (obviously seems like it is in fact not taking) I looped each wheel last night to no avail. BUT I then cut every harness just before the brake wear connectors and looped them there instead! and low and behold it went away when I finally finished on the rear right side. Both rear side harnesses were in absolute shambles the rear left more so as when I touched that harness connector it had actually completely crumbled the wires on the back side. So I just passed inspection this morning and can finally plate my car! No more future inspections thank God for living in hick provinces haha. Thank you again for your help if you are curious to ever figure out why it didn't take the code I am willing to be your guinea pig but until that point it is solved for now wires are stripped, wound together, soldered, and covered with heat shrink hopefully forever.
MrCypherr
Ontario
Mk6 Wagon
Well im glad you got it fixed! You always look before the brake pad connector. I assumed you were doing that already when you were gonna loop the wires.
