Verrico1183
Hello,
Just wondering what is out there for performance upgrades?
Wish I knew that when I purchased the stage 1 yesterday...Deletes are an optional add on, the standard files are designed around stock emissions components.
Audi has always been tough on voiding warranties with tuning, if you are concerned about the warranty, I would avoid it unless you are local to us. We're able to make it undetectable but that requires bench flashing.Picked up a 2015 Q5 TDI that’s been fixed by the dealer a month ago. Still under warranty. I haven’t been able to find a clear answer on how a Malone or JR tune would impact the warranty if something were to happen. Are these tunes completely reversible if I needed to bring the car in for service? I thought I read the ECU tracks each flash?
JR Auto Performance will be offering 3.0L transmission tuning in a few weeks, I have customers coming in to our shop with a 2014 Touareg and a 2015 Q7.Nobody can tune Aisin TCM's, the security has proven to be much better than a German ECM/TCM and they remain uncracked.. many manufacturers use it, if nobody's broken it by now I would not expect it to ever change.
Very interesting development for those unhappy with the new shift points. Please let us know what the price for this service is expected to be.JR Auto Performance will be offering 3.0L transmission tuning in a few weeks, I have customers coming in to our shop with a 2014 Touareg and a 2015 Q7.
If the factory setup is similar to the Q5 TDI then there is really not much to improve upon. I installed an AFE Dryflow filter that is supposed to have a bit more flow capacity than the stock filter but can't say if it really increased power much.Still looking for an intake any ideas?
Not to hijack the thread but do you happen to have a link or part number for the correct AFE dry filter for 2015 Q5 TDI? thanks!If the factory setup is similar to the Q5 TDI then there is really not much to improve upon. I installed an AFE Dryflow filter that is supposed to have a bit more flow capacity than the stock filter but can't say if it really increased power much.
aFe 11-10121 Pro DryNot to hijack the thread but do you happen to have a link or part number for the correct AFE dry filter for 2015 Q5 TDI? thanks!
So do you now offer a TCU tune?Audi has always been tough on voiding warranties with tuning, if you are concerned about the warranty, I would avoid it unless you are local to us. We're able to make it undetectable but that requires bench flashing.
i would like to leapfrog the tune and do a 6 speed swapYes I've heard of someone swapping the TCM to a pre-fixed unit and that worked, might be worth picking up one from a wrecked vehicle that hasn't had the update done. Had a 2014 R line in for a few weeks recently and it wouldn't take VCDS codes post-fix. Aisin units probably won't be cracked ever unfortunately, unless someone puts some brute force in there. Might be able to figure something out with factory tools as well, just been swamped over here. Lots of "might"s and "probably"s though, sure there will be a solution within a couple years if there's enough demand.
Did you get the TCU tuned as well? Interested on your thoughts. I had mine done along with ecu and a delete. Car shifts so smooth and its always sitting in the powerband. As you mentioned turbo lag is gone. Just took a trip and got 720 miles on a tank.THANK YOU for reminding me to follow up!
Mark @ Malone, Owain, AARodriguez, CR Tuning in Peoria...
I simply cannot say enough about all of them. Everyone bent over completely backwards to get this running right for me and the things that messed up were ZERO fault of anyone involved. Just freak "bad luck" sort of things.
I've put more than 4,000 miles on this setup and I absolutely love it.
I'm getting close to 25mpg at 80 on the freeway (used to get 18-19ish)
I have a lifetime average above 26mpg. (used to be 22ish)
If I completely mash it, it does roll a little coal, which I kinda dig... keeps tailgaters at bayThere is definitely more turbo whistle, which I love, but zero highway drone from the exhaust. the motor sounds angrier now when I mash it, more like an F250... Love that too.
The power gains are fantastic.. I actually used the beast to pull out my 16,000lb Winnebago from the mud this weekend...
But by far the biggest gain is the daily driveability. Turbo lag has all but dissappeared, acceleration from intersections and for lane changes is MUCH smoother... overall city driving, it now responds more akin to the v8 or the supercharged 3.0... This is how it SHOULD have been programmed from the factory.
my only two initial complaints were that the exhaust will never be chrome again... which I'm actually growing to like.. and I may wrap the rest of the chrome in flat black to match.
and... I thought that the throttle was a little useless past 70%.. it didn't seem to accelerate any more after that point... flooring it was useless other than to create black smoke. However, I was towing a trailer load of gravel last weekend and I can tell you that the bottom 1/3 of the throttle is actually there if you need it. that power is apparently reserved for VERY heavy loads.
I had planned on asking Mark for a low-smoke tune that I could swap in and out of, but frankly I couldn't imagine ever wanting to modify how this thing runs right now.
She will turn over 200k next week, and I'm probably more excited than when I got her... time for another 200k!
I didn't, but now you have me wondering.Did you get the TCU tuned as well? Interested on your thoughts. I had mine done along with ecu and a delete. Car shifts so smooth and its always sitting in the powerband. As you mentioned turbo lag is gone. Just took a trip and got 720 miles on a tank.
Congrats on everything working out! Enjoy!
