CleverUserName
- Joined
- Oct 25, 2014
- Location
- NorCal
- TDI
- 2014 OZ Cruze CTD & 2010 JSW 6MT & 2017 GMC Canyon CCLB ATX 2.8 Duramax
My 2014 Cruze CTD project car. I got this from a co-worker, it was his wifes car and had 50K milles. It is in good condition, not perfect but it was cheap for a project car at only $8 grand.
These 1st gen Cruze CTDs were different than the other Cruze models and are totally underrated. It has a German Made Opel MultiJet II engine, Aisin Transmission and Suspension/Brakes/Drivetrain parts from Buick and Cadilac. It's basically an Opel Astra 2.0 Sedan with a Chevrolet Body.
Mods:
The OZ tune is good for 180 WHP. The stock turbo is good for another 20-30 HP with custom made injectors.
As tuned, this car is the king of Freeway MPGs. With the stock 17" wheels and V-rated 215/55R17 tires I could get 58 MPGs @ 65 mph. High speed fuel economy is 38-40 MPGs @ 90 mph. The 18" wheels and sticky tires knocked down the fuel economy by about 10%. I think if you put a set of light Enkei 16" wheels and V-Rated LRR tires you could get 60-65 MPGs @ 65 mph in this setup. My 2003, 2009 and 2010 TDIs were all MTs and couldn't come close to this fuel economy.
Mods:
- OZ CRZRACE Tuned. Top Speed limiter Removed and Calibrated for 225/50R18 tires
- OZ Tuner Downpipe
- Bilstein B12 Pro-Kit
- American Racing 18" Wheels
- Michelin Pilot Sport AS3+ W rated 225/50R18 tires
- Whiteline Rear Sway Bar
- Whiteline Front Control Arm Bushings
- All plastic Suspension mounts were replaced with upgraded steel parts from Mevotech
- Mevotech Front Camber Bolts allow -1.5 deg camber on all four corners
- New strut mounts, TTY Bolts, Z-Link and Sway Bar polyurethane bushings
- New Timing Belt, Tensioners, Idlers and Water Pump
