MO Treg
So its got 110K on the odometer, does anyone have an idea when I should start thinking about having the timing belts replaced?
Fixed the question for you. Eager to hear the answers.So its got 110K on the odometer, does anyone have an idea when I should start thinking about having the timing chains replaced?
Good questions that I need to get answers to. I have no rattle when idling and a little bit when I start it from the somewhat warmed up condition. I not sure what slide material is but I don't change my own oil and have it done every 8K at a VW dealership. They have put Castrol Edge in for its full life. I will have them check the camshaft phase position on its' next service. What is the tolerance for this? I really appreciate your help and want to keep my Touareg for a long time.Do you have lots of chain rattle at startup or during idle?
Have you seen evidence of slide material in your drained oil?
What's your camshaft phase position read at warm idle?
Some people have reported that they had chains ready to fail when they got up to 8-9deg, and some have experienced failure once up in those values.Example with '14 with ~100k on it said:IDE00182 Camshaft adaptation intake bank 1: phase position -4.15º
The following is not actually documented in a manual or anything that I've seen, and has been gathered from other users\owners\techs based on claims made on the internet. Use at own risk.
Typically, users with more frequent OCIs, quiet chains and 100-120k on the clock report their adaptation value to be less than -5 deg.
Zero adaptation is a theoretic new chain.
Lots of people believe that reduced OCIs are a huge help, especially when similar "engined" OEMs like Porsche have 5k OCIs instead of the VW ones.
Slide material would be chunks of plastic that would break off your chain tensioner slides if you had all sorts of wear....
Based on what I've leaned thus far, I'd say that a healthy CNRB with ~150k on it and good timing drive should have a value approaching -5 deg.
