TurboABA
- Joined
- Jul 24, 2010
- Location
- Kitchener, ON
- TDI
- RIP-2010 Jetta 6spd 2014 Touareg Execline '14 A6 Technik S-line
My '14 started running hot according to the cluster temp gauge on a 1.5 hr drive in hot ambient temps (90f), on cruise at 60mph. The guage read a consistent 220-230 for most of the trip.
I tried running the cabin heat on full, turning the A/C off, slowing down, etc. Even sitting at a traffic light at idle would not make the guage go hotter or colder.
Once back home, I ran a scan and not evidence of errors. I then read some values and am now struggling to make sense of them.
Does anyone know which sensor the cluster temp gauge reads off? I'm suspecting a failing sensor because my coolant didn't boil, the fan isn't screaming at all times, and I can clearly tell by touch that the rad outlet is way cooler than the inlet. I also don't have any coolant loss, smoke, smell, or any other form of degradation in terms of performance... Just a temp gauge stressing me out.... No CEL, no buzzer, no engine shutdown, no warning messages, etc.
These are the readings I'm looking at.
If anyone has any ideas, I'm open to input or suggestions as I smash my face against this issue.Address 01: Engine (7P0 907 401 K)
19:29:15
IDE00025 Coolant temperature 91 °C
IDE00192 Coolant temperature at radiator outlet: actual value 40.3 °C
IDE00194 Coolant temperature at radiator output: specified value 90.0 °C
IDE00196 Engine oil temperature 91.4 °C
IDE00380 Coolant fan 1: activation 81.51 %
IDE03582 Temperature sensor for engine temperature management 143.2 °C
IDE07724 Coolant temperature at engine outlet: calculated 91.1 °C
IDE09976 Coolant fan 1: activation 81.68 %
