2 stroke oil is meant to be burned but the most important is to lubricate our precious pumps/injectors . Ash-less is better , almost zero deposits in engine or the expensive exhaust systems but in logical ratio 2T/Diesel of course . Ash % of any ash-less 2 stroke is same with ULSD diesel , the limits are max 0.01% at both . No harm at all to engine ,actually it happens the opposite .If ATF didn't cause harm in 400,000 km then I seriously doubt that it is so bad.
I hadn't thought about using 2 stroke oil.
No one except you is "confusing" VW TDI engines with Cummins engines but the fact is that both use Bosch injection pumps and injectors.Yet again: we're confusing pre-CR VW diesels with CR VW diesels and Dodge-Cummins diesels.
They should NEVER be discussed/compared in the same sentence, or even in the same paragraph.
Not so a fact. My Tdi CR uses Delphi pump and injectors . Did i miss something ?or did you miss something?No one except you is "confusing" VW TDI engines with Cummins engines but the fact is that both use Bosch injection pumps and injectors.
This must be done to petrol 2 stroke engines right? Diesel fuel is actually an oil fuel as 2 stroke is too .If any of you have a 2 stroke outboard boat you know that the manufacturer recommends always using ring free additive due to the 2 stroke oil burned in the engine,so if you add 2 stroke oil you will be causing your CR trouble. Carbon build up happens with burned oil in the engines.
I use PS with every fill up,but any quality lubricity product will work. I have 2 TDIs one is the 09 JSW and no trouble.
Are you asserting that the Cummins fuel pumps are the same design and are as frail as the VW CRTDI HPFPs?No one except you is "confusing" VW TDI engines with Cummins engines but the fact is that both use Bosch injection pumps and injectors.
Are you trying to set up a straw man argument?Are you asserting that the Cummins fuel pumps are the same design and are as frail as the VW CRTDI HPFPs?
It would be much easier if they were not "discussed/compared" within the same thread, but we know that will never happen. Here is a link to the report, my assumption, that you are referring to in your last post (#40). The graph on page 12 of the report shows a nice visual representation.Yet again: we're confusing pre-CR VW diesels with CR VW diesels and Dodge-Cummins diesels.
Bias? Not at all. I've been an avid supportive member here for 7 years.Comparing the two Bosch injection systems manufactured for different applications may be "ludicrous" or unwelcome to those with a bias against VW TDIs but you can't erase the fact that Bosch manufactured both systems.
Sometimes truth and facts get in the way of arguments some wish to make but they remain truth and facts.
Yeah, right. Please provide your evidence that VWAG "demanded a cheaper pump than the CP3, and that's exactly what they got."The Bosch CP3 family of hpfp's are legendary for their robustness. The CP4 family- not so much. The manufacturers demanded a cheaper pump than the CP3, and that's exactly what they got.
