2014 Sportwagon: timing belt and engine/trans mounts
terriblespeller
Oakland
2014 Jetta Sportswagon
Hello, our sports wagon has 100k and its great. We have it listed on FB marketplace for $10k, but I'm thinking of keeping it and selling my Toyota Matrix (back story, the TDI is my wife, she bought a new electric and doesn't want two cars).
I've had a tech tell me the engine mounts (and I believe trans mounts as well) need to be replaced. Also, that the timing belt is deterorating due to age. I'm handy and it seems the kit is an easy/cheap solution. I'm wondering if doing the engine mounts while doing the belt make sense or if it opens another can of worms and is best left for a pro.
Ability wise, I am very able and capable hands on type, however I do not have much experience with autos (mainly carpentry, metal work, electronics, etc).
do you all think I'd be best off having a tech do this or will I be able to also change the mounts while I'm in there without creating a nightmare for myself?\
thanks
lemoncurd
PNW
2013 CJAA GTB2266
thanks
it is pretty easy to do, i did it in a weekend while taking my time. could probably do it in 3-4 hours now.
it is easy to replace the motor mounts while doing timing belt, if you follow VW SOP then you are SUPPOSED to remove the engine mount anyways! simply replace with a new one when putting it all back together. the trans mount is also easy pz, remove the battery, then battery tray, then support transmission from below with jack, and remove the mount.
fwiw, when i did my timing belt, i did NOT remove that metal cage thing, nor did i remove the engine mount. i removed the tensioner WITH the stud, the "pro" method.
when i do my service again, i will do it exactly like this again.
replacing the mounts by themselves takes like maybe 30mins to an hour. i can do it pretty quick no problem. the worst part is getting the damn battery out of the engine bay. thing is a boat anchor!
EDIT: the IDparts kit is good. however i would just use it to compile a list of PN's you need to do the job. then go buy those parts from FCPeuro. their lifetime warranty is great!!
turbobrick240
maine
C'mon man, the battery? It's tiny, and they even put a handle on it. What's the metal cage thing?
Nuje
Island near Vancouver
Thanks for digging those how-tos out of the Internet Archive! Such a shame what happened to MyTurboDiesel.com when @chittychittybangbang gave up (or lost, or sold) control.
lemoncurd
PNW
2013 CJAA GTB2266
Yes, the battery is the worst part of a transmission mount job. That should show you how easy the job really is
metal cage thing = what the engine mount attaches to the engine with. I don’t recall the name of it so, metal cage thing lol
turbobrick240
maine
Cool. I just call that the mount. I did the vice grip to tensioner stud method too, so never messed with that.
terriblespeller
Oakland
How much would you guys pay to have a tech do it? Just to save time and aggravation. Or is really just super easy?
Bob S.
Central MD.
A B4V, some ALHs & BRMs
As you R&R the Timing Belt, IMO & experience, replacing the lower timing belt cover with the reduced clearance cover is a very prudent investment given the number of CR engines where the serpentine belt entered the Timing Belt area typically from alternator pulley problems. Search the subject if unfamiliar with it. These are available from most of the trusted suppliers. https://whitbreadperformance.com/products/common-rail-tdi-lower-timing-belt-cover
lemoncurd
PNW
2013 CJAA GTB2266
labor costs are quite high now.
i see timing belt quotes go for 1.7-2k frequently. including parts
if youre comfortable working on cars, and you have the time i would personally do it myself. but nothing wrong with letting a shop do it
vincej
Calgary
2014 Golf Wagon
I installed our timing belt and serpentine belt kits this weekend. How long does an alternator last? So far the pulley clutch is still OK. Ours has 178k kms (111k mi).
P2B
Toronto & Muskoka, Canada
On the ALH I install a new alternator pulley during the timing belt job because they rarely last until the next TB. Not sure if that applies to the newer cars, but I suspect it does.
lemoncurd
PNW
2013 CJAA GTB2266
i have 236k miles on my CJAA now, the alternator pulley clutch seems to be going out right about now. just in time for my second timing belt
Bob S.
Central MD.
That is one that I would not ignore. If you don't have it yet, install a reduced clearance lower T belt cover during the service. Enjoy the wrenching.
cdi320
Ontario, Canada
Cdi
Going to slightly thread hijack here, but why does the battery need to be removed to do the transmission mount? I had the airbox out a while back when I was adjusting the shift linkage and from what I remember, the transmission mount is readily accessible with the airbox removed, but I wasn't paying close attention to it. I ask because I'll be doing my mounts soon aswell
lemoncurd
PNW
2013 CJAA GTB2266
i've replaced my transmission mount 3 times now. it may be different for a manual, but i know for certain with my DSG the battery tray must be removed, therefor the battery must be removed.
otherwise the mount is just inaccessible. even a manual should be the same procedure... transmission type wont change where the mount connects to the vehicle.
cdi320
Ontario, Canada
Cdi
Yea probably on a manual too, I will see when I do mine in the coming months, thanks for the info
