2014 Jetta Sportwagen TDI deleted, rawtek turbo back exhaust, neuspeed tubo discharge pipe, cr170 turbo, Malone stage 3 tune and trans tune 56k miles on the OD. Starting to notice last year of prolong starts. If I turn the key let glow plugs light turn off and try cranking its could be a 5-8 second crank before it fires. If I do a glow plug cycle on off back on it seems to be less cranking before it fires. I do get a puff of white smoke when it does fire. Once the car is running no issues with starting. Almost seems like I am losing fuel pressure over night. Replaced battery last year and replace the fuel filter every year. Im at a loss and just seeing if anyone has had this issue an what they did to fix it. I do have VCDS if needed. Thanks for the help!
