2014 JSW code P2457 after DPF replacement
brkdrvr
Milton, DE
2011 JSW TDI 6spd manual 140K, 2013 JSW TDI A/T 50K, 2014 JSW TDI A/T 40K, Ross Tech VCDS-MOBILE
Hello, Just replaced DPF (CEL w/code 2457 & massively sooted exhaust pipe). We replaced DPF and low pressure EGR cooler filter pipe and reset DPR in adaptations, at the same time we performed timing belt service (Belt, rollers tensioner & water pump) as it was over due 115,000 miles and also did 2nd trans service while it was on jack stands. My daughter drove the car about 20 miles to work and got the P2457 code on the return trip home. The coolant was just below min and we added more heater works fine and makes plenty of heat so I assume the heater core is not blocked. We are going to pull the EGR Valve and EGR cooler valve and clean next. I will try and post the latest scan as soon as I can get it from my PC to this thread>
THX for any suggestions,
Mike
Thursday,24,October,2024,10:14:28:31396
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 24.7.1.0 (x64) HEX-NET CB: 0.4643.4
Data version: 20240919 DS356.3
www.Ross-Tech.com
VIN: 3VWPL7AJ9EM610809 License Plate: WHT2014JSW102424
Mileage: 184770km-114810mi Repair Order:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 4F 52 56 62 72
77
VIN: 3VWPL7AJ9EM610809 Mileage: 184770km-114810miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1C-Position Sensing -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 997 030 E HW: 03L 907 309 AA
Component: R4 2.0l TDI G000AG 9983
Revision: 12H16--- Serial number:
Coding: 0050078
Shop #: WSC 27303 006 1048576
VCID: 302CD70AA359F7167B-8064
VINID: 0E69E070745A25574604020024D058765C
1 Fault Found:
009303 - Exhaust Gas Recirculation System
P2457 - 000 - Insufficient Cooling Performance - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100000
Fault Priority: 2
Fault Frequency: 3
Reset counter: 255
Mileage: 184727 km
Time Indication: 0
Date: 2019.03.17.
Time: 04:31:60
Freeze Frame:
RPM: 2116 /min
Speed: 107.0 km/h
Temperature: 81.9°C
Temperature: 384.0°C
(no units): 71.4
Temperature: 162.0°C
Temperature: 150.0°C
Readiness: 1 1 0 0 0
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 062 B HW: 02E 927 770 AL
Component: GSG DSG AG6 521 9430
Revision: 05652104 Serial number: 00001310071952
Coding: 0000020
Shop #: WSC 00066 000 00000
VCID: 14647B9A37012B367F-8040
No fault code found.
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BM HW: 1K0 907 379 BM
Component: ESP MK60EC1 H46 0164
Revision: 00H46001
Coding: 114B600C492300FA881306E492220042A1000022
Shop #: WSC 00066 790 00014
VCID: 7EB03932E98DD166B9-802A
1 Fault Found:
01325 - Control Module for Tire Pressure Monitoring (J502)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 124
Mileage: 184701 km
Time Indication: 0
Date: 2019.03.17.
Time: 00:25:36
Freeze Frame:
Count: 16386
Count: 12
Count: 29184
Count: 16390
Count: 49920
Count: 0
Count: 0
Count: 11520
Address 08: Auto HVAC (J301) Labels:| 3C8-907-336.clb
Part No SW: 7N0 907 426 CA HW: 7N0 907 426 CA
Component: AC Manuell H20 0606
Revision: 00001002
Coding: 0010002002
Shop #: WSC 00066 000 00119
ASAM Dataset: EV_ACManueBHBVW36X A01010
ROD: EV_ACManueBHBVW36X_VW36.rod
VCID: 75A2261ED4BB923EE8-8020
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 5K0 937 084 N HW: 5K0 937 084 L
Component: BCM PQ35 B 122 1184
Revision: BG122001
Coding: AF380E1F802F3EC4008800C17000004449000086535D0520648020200040
Shop #: WSC 40942 003 1048576
VCID: 3D32FE3EA40B0A7EE0-8068
Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 20011 26 0512
Coding: 009795
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 5C0 959 655 M HW: 5C0 959 655 M
Component: AirbagVW10G 014 0726
Serial number: 003L4R02SS6X Dataset Number: 1KM003v__B_ 0047
Coding: 00004E42
ASAM Dataset: EV_AirbaVW10SMEVW360 001026
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3C34F33AB7110376D7-8068
Seat occupied recognition:
Subsystem 1 - Part No SW: 1KM 959 339 B HW: 1KM 959 339 B
Component: BF-Gewichtss. 006 0001
Serial number: ---0000R--00009N0S00
Crash sensor for side airbag: driver side:
Subsystem 2 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Component: S.Sens.Fahr.V H02 ----
Serial number: 3572MSME1A64037CZZZ-
Front Passenger's Side Airbag Crash Sensor:
Subsystem 3 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Component: S.Sens.Beif.V H02 ----
Serial number: 3582MSME7364037CZZZ-
Rear Side Airbag Crash Sensor (on driver's side):
Component: S.Sens.Fahr.H --- ----
Serial number: 3511HSME7433722FZZZO
Passenger side rear thorax airbag crash sensor:
Component: S.Sens.Beif.H --- ----
Serial number: 3521HSME4F080530ZZZH
Crash sensor for front airbag: driver side:
Component: F.Sens.Fahr --- ----
Serial number: 35527SME245D7D2FZZZ.
Crash sensor for front airbag: front passenger side:
Component: F.Sens.Beif --- ----
Serial number: 35627SME2E170030ZZZ4
Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
Part No SW: 5K0 953 507 AH HW: 5K0 953 549 B
Component: Lenks.Modul 008 0090
Revision: -------- Serial number: 90422MLD000RL Dataset Number: 5K0953507AH D005
Coding: 188A140000
ASAM Dataset: EV_SMLSNGKUDS A05001
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 76A02112C9BD9926E1-8022
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H31 0037
Serial number: 0504864 FLE 20131214
Coding: 820000
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 5K0 920 973 G HW: 5K0 920 973 G
Component: KOMBI H04 0811
Serial number: 00000000000000
Coding: 270F01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04721
ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
VCID: 3522E61E943BD23E28-8060
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 AM HW: 7N0 907 530 AM
Component: J533 Gateway H55 1642
Revision: H55 Serial number: 16011403001106
Coding: 352002
VCID: 7BB63026FA9FC44E9E-802E
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 5N0 919 879 HW: 5N0 919 879
Component: Kompass 002 0002
Revision: 00002000 Serial number: 1225223RPKFA07
Coding: 0000002
VCID: 7EB03932298DD166B9-802A
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H04 0811
Serial number:
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09_VW23.rod
VCID: 6A9805628D054DC675-803E
Address 2E: Media Player 3
Cannot be reached
Address 42: Door Elect, Driver (J386) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 561 959 701 HW: 3C0 959 793 B
Component: TUER-SG FT 002 0501
Revision: 13110009 Serial number: 0007845408
Coding: 0004B5
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
ROD: EV_TSGFPQ35BRFVW46X_VW36.rod
VCID: 5BF650A6525F244EFE-800E
Slave Driver:
Subsystem 1 - Part No SW: 3C0 959 703 C HW: 3C0 959 795 D Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 009 1509
Serial number: 00000008395526
Coding: 000490
2 Faults Found:
66048 - Motor for Front Window Regulator
B11EC 54 [00001001] - Missing Calibration / Basic Setting
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 83
131584 - Motor for Rear Window Regulator
B11EE 54 [00001001] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 83
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 70 3501
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 393AEA2E7023365ECC-806C
Address 4F: Centr. Electr. II (J520) Labels:. 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 7N0 907 530 AM
Component: EZE_2 H55 1642
Coding: 050B0500
VCID: 6FAE1476BEE7A8EE22-803A
Subsystem 1 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H05 0220
Serial number: 0123456789ABCDEFGHIJ
Subsystem 2 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE20SKB13 H05 0220
Address 52: Door Elect, Pass. (J387) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 561 959 702 HW: 3C0 959 792 B
Component: TUER-SG BT 002 0501
Revision: 15110009 Serial number: 0007832206
Coding: 0004B4
ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
ROD: EV_TSGBPQ35BRFVW46X_VW36.rod
VCID: 5CF453BA57512376F7-8008
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 704 C HW: 3C0 959 794 D Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 009 1509
Serial number: 00000008095925
Coding: 000490
2 Faults Found:
B11EC 54 [00001000] - Missing Calibration / Basic Setting
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 123
B11EE 54 [00001000] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 123
Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 1K0 035 188 F HW: 1K0 035 188 F
Component: Radio Prem-8 H07 0008
Revision: -----11S Serial number: VWZ4Z7P3531242
Coding: 01000440040007
VCID: 2B16C0664A7F94CE4E-807E
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 83
Mileage: 184701 km
Time Indication: 0
Date: 2019.03.16.
Time: 18:29:59
Address 77: Telephone (J412) Labels:| 5N0-035-729.clb
Part No SW: 5N0 035 729 A HW: 5N0 035 729 A
Component: TELEFON H05 0315
Revision: 1B001001 Serial number: 00007665532236 Dataset Number: 5N0035729A 0001
Coding: 0A10030080010110
ASAM Dataset: EV_UHVUMI 001007
ROD: EV_UHVUMI.rod
VCID: 2E10C972716DE1E669-807A
End----------(Elapsed Time: 01:28, VBatt start/end: 12.5V/12.5V)-----------
brkdrvr
Milton, DE
Update the P2457 code has cleared after a couple of short 20 mile drives and two additions for a total of about 1/2 pint of coolant. I am surprized that even though the engine never overheated the heater worked fine from the start and the coolant level never dropped more than 1/4" below the low mark the EGR cooler sensors "saw" insufficient cooling performance. I can only assume that some small bubble of air in the system was causing the issue. My daughter has been driving now for over a week through at least one re-gen cycle with no CEL.
