2014 Jetta TDI Value Edition Flashing Glow Plug Light
gsmith2424
Maiden, NC
2014 Jetta TDI Value Edition DSG
Coming home tonight I have now had my first problem with my car after 35k miles. While cruising at 70 mph the glow plug light started to flash and prior to that (about 3 miles) I felt a pulse/surge while at speed. While driving it to the dealership I felt no noticeable loss of power and the mileage looked to be about what it should be for the roads I was on. It is now at the dealership (Hendrick VW Concord, NC) and from talking with the service tech that was there and telling him what I was experiencing he fells like it might be the DPF as the last 3 or 4 regens did not go to the normal RPM for a regen (1000 normal vs 800 for the last ones I had). Anyone have any other thoughts on if what I was told could/would be the issue or something else? I should have the trouble codes in the morning from them to give more information on the exact issue.
For information my normal drive everyday is 70 miles round trip with about 80% highway at 65 to 70 mph with 100+ mile trips about every other month. I also fill up between 3 stations when home (all high traffic for diesel) and use an additive (Howes or Power Service Silver) to help with lubrication.
gsmith2424
Maiden, NC
Update: They are telling me that it is the Exhaust Temp Sensor that went bad.
Is there anything else that should be checked if that went bad?
John_Nutt
Ontario, Canada
2011 Jetta Comfortline TDI with a DSG automatic 6 speed
I had the flashing glow plug light, shut down and wouldn't start again, dealer changed 2 injectors (they covered 60% of repair). Got my car back drove it 60km and it shut down with the flashing glow plug light again. Called the vw dealer that changed the injectors, they towed it in, spent 2 days trying to figure out what was wrong, turned out to be the electronic engine control module (ecu was under warranty thank god).
I was 2000km from home (visiting family)and I noticed weird missing or something a couple times pulling away from rest stops merging on the highway.
Apparently when the ecu fails it sends strange codes, the ecu doesn't know when it is failing I guess.
John_Nutt
Ontario, Canada
The rpm's were up and down about 200 on the gauge while sitting at a red light just before it shut down the second time.
Matt927
Northeast
several
A flashing glow plug light indicates severe fault in the car which could be any number of issues.
gsmith2424
Maiden, NC
Update 1/25/2016: Same problem has come back and it has the same code for the same sensor.
Update 1/26/2016 AM: Heard back from the dealer it is a different sensor this time but it still had the same code as the last one also. With this now popping up twice is there concern for a cascade effect or is this just bad timing to have two sensors go? Once I know the actual sensor that went I will post it.
faultymechanics
Vermont
1992 Jetta Ecodiesel, 2015 Jetta TDI SEL
I would almost say there is something shorting and frying your sensors or doing something wonky. Electronics like those sensors should last well over a year. I smell lemons......
gsmith2424
Maiden, NC
That's what I've been thinking also. I've had the car since Aug 2014 and this has been the first issue I've had. I figure now that I've probably driven 2000 miles or so with the sensors acting up and it only flashed the plug light for the first time 400 miles ago.
740GLE
NH
When mine has rough regens starts I've had a bouncy tach for 15 seconds or so until it settles out at 1000rpm.
Couple of times (5-8) coasting down hill and tossing the clutch in, the RPMS dropped all the way to zero, and had to quickly fire it back up. The control loop for the regen sometimes can't compensate with everything else going on. Never a code or GP and drove fine after.
Jupiter9
NewYork
2014 jetta tdi
2014 Jetta tdi, been sitting for 4yrs, battery was completely dead, got a new battery car won’t start…. My glow plug like is flashing and below is the codes I found
OBDeleven vehicle history log
Date: 2024-07-12 20:14:03
VIN: 3VW3L7AJ9EM385693
Car: Volkswagen
Year: 2014
Body type: Saloon
Engine: CJAA kW ( hp) l
Mileage: 114660 km
Full scan
Control Units: 12
Fault count: 20
Control Units:
08 Air Conditioning
System description: J301 Klimaanlage
Software number: 5C0820047BA
Software version: 0204
Hardware number: 5C0820047BA
Hardware version:
Faults:
01316 - Brake control module
static
priority - 6
frequencyCounter - 1
drivingCycle - 56
km-Mileage - 114663 km
01 Engine
System description: R4 2.0l TDI G000SG
Software number: 03L997030N
Software version: 9983
Hardware number: 03L907309AA *
Hardware version: 78
Faults:
P169800 - Steering Column Electronics
Read out DTC
static
priority - 6
frequencyCounter - 2
drivingCycle - 255
P263200 - Fuel Pump "B" Control Circuit
Open
static
priority - 2
drivingCycle - 255
P038300 - Glow Plug Control Module Control Circuit Low
static
priority - 2
drivingCycle - 255
P062700 - Fuel Pump "A" Control
Circuit/Open
static
priority - 2
drivingCycle - 255
P263300 - Fuel Pump "B" Control Circuit
Low
static
priority - 2
drivingCycle - 255
U012100 - Lost Communication With
Anti-Lock Brake System (ABS) Control Module
static
priority - 2
drivingCycle - 255
P062800 - Fuel Pump "A" Control
Circuit Low
static
priority - 2
drivingCycle - 255
44 Steering Assistance
System description: EPS_ZFLS Kl. 70
Software number: 1K0909144R
Software version: 3501
Faults:
03803 - Steering angle sensor for power-assisted steering
static
priority - 2
drivingCycle - 255
static
priority - 3
drivingCycle - 56
09 Central Electrics
System description: BCM25 JLB H3
Software number: 5C0937087L
Software version: 0425
Hardware number: 5C0937087A
Hardware version: H34
Faults:
01326 - Multifunction steering wheel control module
static
priority - 2
drivingCycle - 56
56 Radio
System description: Radio Prem-8
Software number: 1K0035188F
Software version: 0008
Hardware number: 1K0035188F
Hardware version: H05
Faults:
00625 - Speed signal
static
priority - 6
drivingCycle - 56
02635 - Tuner not enabled/activated
static
priority - 7
drivingCycle - 56
19 Gateway
System description: GW-K-CAN TP20
Software number: 6N0909901
Faults:
static
priority - 2
drivingCycle - 56
25 Immobilizer
System description: IMMO
Software number: 5K0953234
Software version: 0809
Hardware number: 5K0953234
Hardware version: H04
Faults:
No trouble codes found
77 Telephone
System description: TELEFON
Software number: 5N0035729A
Software version: 0315
Hardware number: 5N0035729A
Faults:
47 Sound System
System description: KonzernAmp10K
Software number: 5C6035456A
Software version: 6813
Hardware number: 5C6035456A
Hardware version: H07
Faults:
B106613 - Left rear treble speaker
Open circuit
static
Priority - 5
Malfunction frequency counter - 1
Unlearning counter - 56
date - 2100-12-06 03:55:26
15 Airbag
System description: AirbagVW10
Software number: 5C0959655AD
Software version: 0912
Hardware number: 5C0959655AD
Hardware version: 102
Faults:
static
Priority - 6
Malfunction frequency counter - 2
date - 2100-12-06 03:49:49
B10B200 - Function restriction of seat occupied recognition
due to missing message
static
Priority - 2
date - 2100-12-06 03:50:05
17 Dashboard
System description: KOMBI
Software number: 5C6920953A
Hardware number: 5C6920953A
Faults:
U111100 - Function limitation due to missing message
static
Priority - 6
75 Telematics
System description: OCULowUSA
Software number: 561035285
Software version: 0086
Hardware number: 561035285
Hardware version: 014
Faults:
U041500 - Invalid Data Received From
Anti-Lock Brake System Control Module
static
Priority - 2
date - 2100-12-06 04:01:49
B1788F0 - Control module
Immobilizer deactivated
static
Priority - 8
date - 2100-12-06 03:55:25
Full scan
Control Units: 12
Fault count: 20
Control Units:
25 Immobilizer
Faults:
77 Telephone
Faults:
Faults:
static
priority - 2
drivingCycle - 56
Faults:
static
priority - 2
drivingCycle - 255
static
priority - 3
drivingCycle - 56
19 Gateway
Faults:
static
priority - 2
drivingCycle - 56
56 Radio
Faults:
static
priority - 6
drivingCycle - 56
static
priority - 7
drivingCycle - 56
08 Air Conditioning
Hardware version:
Faults:
static
priority - 6
drivingCycle - 56
01 Engine
Faults:
Read out DTC
static
priority - 6
drivingCycle - 255
Open
static
priority - 2
drivingCycle - 255
static
priority - 2
drivingCycle - 255
static
priority - 2
drivingCycle - 255
Circuit Low
Intermittent
priority - 2
drivingCycle - 255
Low
static
priority - 2
drivingCycle - 255
Circuit/Open
static
priority - 2
drivingCycle - 255
17 Dashboard
Faults:
static
Priority - 6
15 Airbag
Faults:
static
Priority - 6
static
Priority - 2
75 Telematics
Faults:
static
Priority - 8
static
Priority - 2
47 Sound System
Faults:
Open circuit
static
01 Engine
Faults:
Read out DTC
static
priority - 6
drivingCycle - 255
Open
static
priority - 2
drivingCycle - 255
Circuit/Open
static
priority - 2
drivingCycle - 255
static
priority - 2
drivingCycle - 255
Circuit Low
Intermittent
priority - 2
drivingCycle - 255
static
priority - 2
drivingCycle - 255
Low
static
priority - 2
drivingCycle - 255
75 Telematics
Faults:
static
Priority - 2
static
Priority - 8
01 Engine
Faults:
Read out DTC
static
priority - 6
drivingCycle - 255
Full scan
Control Units: 12
Fault count: 19
Control Units:
25 Immobilizer
Faults:
77 Telephone
Faults:
08 Air Conditioning
Hardware version:
Faults:
static
priority - 6
drivingCycle - 56
01 Engine
Faults:
Read out DTC
static
priority - 6
drivingCycle - 255
Circuit/Open
static
priority - 2
drivingCycle - 255
Open
static
priority - 2
drivingCycle - 255
static
priority - 2
drivingCycle - 255
static
priority - 2
drivingCycle - 255
Low
static
priority - 2
drivingCycle - 255
19 Gateway
Faults:
static
priority - 2
drivingCycle - 56
56 Radio
Faults:
static
priority - 6
drivingCycle - 56
static
priority - 7
drivingCycle - 56
Faults:
static
priority - 2
drivingCycle - 56
Faults:
static
priority - 2
drivingCycle - 255
static
priority - 3
drivingCycle - 56
47 Sound System
Faults:
Open circuit
static
17 Dashboard
Faults:
static
Priority - 6
15 Airbag
Faults:
static
Priority - 6
static
Priority - 2
75 Telematics
Faults:
static
Priority - 8
date - 2100-12-06 03:49:52
static
Priority - 2
01 Engine
Faults:
Read out DTC
static
priority - 6
drivingCycle - 255
Full scan
Control Units: 12
Fault count: 19
Control Units:
25 Immobilizer
Faults:
77 Telephone
Faults:
Faults:
static
priority - 2
drivingCycle - 56
Faults:
static
priority - 3
drivingCycle - 56
static
priority - 2
drivingCycle - 255
56 Radio
Faults:
static
priority - 6
drivingCycle - 56
static
priority - 7
drivingCycle - 56
08 Air Conditioning
Hardware version:
Faults:
static
priority - 6
drivingCycle - 56
19 Gateway
Faults:
static
priority - 2
drivingCycle - 56
01 Engine
Faults:
Circuit/Open
static
priority - 2
drivingCycle - 255
Read out DTC
static
priority - 6
drivingCycle - 255
Open
static
priority - 2
drivingCycle - 255
static
priority - 2
drivingCycle - 255
Low
static
priority - 2
drivingCycle - 255
static
priority - 2
drivingCycle - 255
17 Dashboard
Faults:
static
Priority - 6
47 Sound System
Faults:
Open circuit
static
15 Airbag
Faults:
static
Priority - 6
static
Priority - 2
75 Telematics
Faults:
static
Priority - 2
static
Priority - 8
Full scan
Control Units: 12
Fault count: 52
Control Units:
25 Immobilizer
Faults:
01 Engine
Faults:
Read out DTC
static
priority - 6
drivingCycle - 255
static
priority - 2
drivingCycle - 255
Low
static
priority - 2
drivingCycle - 255
Circuit/Open
static
priority - 2
drivingCycle - 255
Open
static
priority - 2
drivingCycle - 255
static
priority - 2
drivingCycle - 255
19 Gateway
Faults:
01314 - Engine control module (ECM)
Intermittent
priority - 2
drivingCycle - 96
static
priority - 2
drivingCycle - 56
08 Air Conditioning
Hardware version:
Faults:
00447 - Function limitation due to excessive voltage
Intermittent
priority - 6
frequencyCounter - 23
drivingCycle - 96
00446 - Function limitation due to insufficient voltage
Intermittent
priority - 6
frequencyCounter - 50
drivingCycle - 96
00532 - Supply voltage
Intermittent
priority - 3
drivingCycle - 96
Intermittent
priority - 6
drivingCycle - 96
static
priority - 6
drivingCycle - 56
Intermittent
priority - 3
frequencyCounter - 4
drivingCycle - 96
56 Radio
Faults:
static
priority - 7
drivingCycle - 56
km-Mileage - 65072 km
Intermittent
priority - 3
drivingCycle - 96
Intermittent
priority - 3
drivingCycle - 96
static
priority - 6
drivingCycle - 56
Intermittent
priority - 3
drivingCycle - 95
Faults:
static
priority - 2
drivingCycle - 255
static
priority - 3
drivingCycle - 56
Faults:
03430 - Terminal 30 for turn signals/ brake lights
Intermittent
priority - 2
drivingCycle - 96
03396 - Supply voltage terminal 30 for central locking
Intermittent
priority - 2
drivingCycle - 96
Intermittent
priority - 3
frequencyCounter - 7
drivingCycle - 96
Intermittent
priority - 3
frequencyCounter - 14
drivingCycle - 96
Intermittent
priority - 6
frequencyCounter - 22
drivingCycle - 96
01598 - Drive battery voltage
Intermittent
priority - 3
drivingCycle - 96
Intermittent
priority - 6
frequencyCounter - 75
drivingCycle - 96
static
priority - 2
drivingCycle - 56
01332 - Frt.pass. side door control module
Intermittent
priority - 2
drivingCycle - 96
01334 - Right rear door ctrl. module
Intermittent
priority - 2
drivingCycle - 96
47 Sound System
Faults:
Open circuit
static
Priority - 5
date - 2100-12-06 03:46:47
U140000 - Function restriction
Intermittent
Priority - 5
Unlearning counter - 96
date - 2097-12-14 00:12:55
17 Dashboard
Faults:
Intermittent
Priority - 6
date - 2097-12-14 02:12:05
static
Priority - 6
date - 2099-12-28 00:00:43
U101100 - Supply voltage
Voltage too low
Intermittent
Priority - 6
Unlearning counter - 40
date - 2097-12-14 00:00:00
U140100 - Function restriction
Intermittent
Priority - 6
Malfunction frequency counter - 25
date - 2097-12-12 00:00:00
15 Airbag
Faults:
static
Priority - 6
static
Priority - 2
date - 2099-12-28 00:01:44
Voltage too low
Intermittent
Priority - 2
date - 2097-12-14 00:00:56
B10B400 - Function restriction of seat occupied recognition
due to undervoltage
Intermittent
Priority - 2
Malfunction frequency counter - 6
date - 2095-12-26 01:21:51
75 Telematics
Faults:
U001000 - Medium Speed CAN Communication Bus
Intermittent
Priority - 1
U112100 - Databus missing message
Intermittent
Priority - 6
Malfunction frequency counter - 191
Unlearning counter - 95
km-Mileage - 83997 km
date - 2056-12-29 21:31:26
Intermittent
Priority - 6
Malfunction frequency counter - 11
km-Mileage - 112918 km
date - 2085-12-20 19:12:32
static
Priority - 2
date - 2100-12-06 03:46:13
Voltage too low
Intermittent
Priority - 3
Malfunction frequency counter - 3
date - 2097-12-14 00:00:09
Intermittent
Priority - 6
date - 2099-12-28 00:11:19
Intermittent
Priority - 6
Malfunction frequency counter - 10
date - 2095-12-26 01:24:33
static
Priority - 8
Unlearning counter - 0
B105213 - Cell phone prep. ctrl. head/emergency call module
Open circuit
Intermittent
Priority - 4
date - 2095-12-26 01:26:09
B149AF2 - Mobile Online services
Remote control for vehicle signaling
Intermittent
Priority - 7
Unlearning counter - 105
km-Mileage - 110973 km
date - 2082-12-07 14:35:17
77 Telephone
Faults:
Intermittent
Priority - 6
km-Mileage - 114439
date - 2095-12-26 01:21:43
borninabus
Arizona
-2013 JSW 6MT- -2012 Touareg Sport- -2015 Jetta 6MT-
most of the codes are probably from the dead battery
reset them and see which ones come back
