Group,
I have searched the forum and it seems like I am not the only one with this problem, but I don't see a 'definitive" fix. My problem is that after sitting for a bit (8-12 hours) sometimes it takes a long time from my car to start. It will crank for a while, I will stop because I don't want to harm the starter or the battery, I will cycle the key a few times thinking it is the fuel pump, try again, it may start but it might crank for a while again. After a bit, it will start. Once started it runs fine, no error code (I have a VCDS) and it will restart without an issue. After searching I see several posts on here and things range from crank senser, glow plug relay, key switch, ECU or the VVT system. Has anyone on here figured out this issue that seems to be plaguing these cars. Again I love the car, but don;t feel like having a battery go dead cranking it or ruining a starter.
Any ideas or definitive fixes out there?
