iamatt
Hey guys been rocking a 2014 jetta for some years now. I rarely drive since working from home but here is a problem that hopefully someone can help me diagnose. The a/c basically stopped working. The fan clutch does not engage. I put some gauges and there is pressure. I swapped the low pressure sensor just for fun but this did not solve anything. One thing I did fix was the RCV valve a few years ago. The AC lights inside the vehicle illuminate orange when you press the button if that matters, just the clutch does not engage. I do have the vag com software and cable but it has been so long since I used it I'm not sure if that is helpful in diagnosing the AC. Any places I should start checking to isolate the problem? I hate to take it to a shop and spend 8-1200 for a full ac job when it might just be a clutch I can change on the car without dumping the system. Thanks.
