GG2
It seems VW changed the software interface in '14 on the Dynaudio for the worst. Is there any way to revert only the Dynaudio software to the 2013 version in a 2014 or newer Touareg TDI with Dynaudio? Thanks
Sound and volume settings
Please first read and heed the WARNINGS , note the introductory information and heed
the WARNINGS
Press the SETUP Infotainment button.
Press the Sound function key.
Changes made in settings menus are automatically applied once the menu is closed.
Function key: Effect
Dynaudio Confidence: Dynaudio-Confidence® settings
Treble - Bass : Changing sound character. Change settings by moving the slider .
Balance - Fader : Changing the sound focus
Volume: Volume settings.
Voice guidance: Set output volume for navigation announcements during route guidance.
Reduced audio volume Set how much the volume for other audio sources should
be reduced during a navigation announcement. The current audio source is set to
the reduced volume while you change the settings.
Parking distance warning system: Set output volume for beeping signals (front and rear).
Reduced audio volume: Set how much the volume for other audio sources should
be reduced while a beeping signal sounds. The current audio source is set to the
Telephone5: Set output volume for telephone calls in the vehicle.
Speed-dependent volume adjustment : If the speed-dependent volume is activated, the audio
volume is automatically raised as the vehicle speed increases.
When speed-dependent volume is switched on in vehicles with Dynaudio Confidence®, the volume
of individual frequencies is automatically raised or reduced depending on the road noise caused by
the rising vehicle speed. This “reduces” the road noise in the vehicle.
Changing the sound focus (balance and fader) using the vehicle diagram
Press the Balance - Fader function key.
The crosshair in the vehicle diagram shows the current sound focus in the vehicle interior.
Place your finger on the crosshair and, without lifting it off, drag it across the screen. Lift your finger
off the screen once the sound focus is in the required position (Moving objects).
OR: Press the point in the interior view where you want the sound focus to be.
OR: Move the sound focus step by step by pressing the arrow buttons on the left of the screen.
Press the function key between the arrow buttons to return the sound focus to the center of the interior
view.
Additional settings are available if the vehicle is equipped with the RNS 850 and Dynaudio.
5 Only when a mobile phone or a SIM card is connected to the Infotainment System ⇒ page 400.
In the Sound settings main menu, press the Dynaudio Confidence main menu.
Dynaudio Presets : Set sound profile and tone color.
Individual : Move slider to change setting for tone color.
Authentic , Soft , Dynamic , Speech: Press to select sound profile.
Surround: Set level of surround effect.
Look again.however the Surround numeric adjustment is missing in the 14.'
Manual said:Dynaudio Confidence®
► In the Sound settings main menu, press the Dynaudio Confidencemain menu.
Press one of the function keys in the Dynaudio settings menu to open the corresponding settings
menu.
Sound focus: Optimize sound effects, frequency ranges and sound focus for different sitting positions in
the vehicle.
