2013 Touareg Battery Dead, Can’t Unlock, Plastic Manual Keys Don’t Work
Ptburkis
Camberley
VW Touareg 2013 3.0TDI Altitude
Hi all,
As per the title, I’ve got a 2013 Touareg 3.0TDI (204ps) Altitude that’s just done 102k Miles.
The battery died yesterday after it broke down on the motorway after having a low fuel pressure issue (that’s a problem for another day!). However, in the process of waiting 4 hours for a recovery truck to come and get me, the battery drained. Then over night completely died.
So, the remote fobs do nothing. I then took the manual cover off the drivers side door and attempted to unlock with the manual plastic keys within the fobs, that doesn’t work either. It makes a little noise like it’s trying to do something electrical to unlock them and I see some lights on the dash, but the doors fail to unlock.
Sooooo.... what do I do?
There doesn’t seem to be another manual key hole anywhere
The only way to open the bonnet is via the release pull inside the car so I can’t charge the battery
There’s no manual way into the boot
Any ideas??
showdown 42
naples,FL
2016 TDI touareg
I'm interested in this one. I had an issue with the fuel door not opening and found out that there is no remote way to open it in the boot or car interior. We're talking about the 2011 on models. Would pose quite an issue on a road trip. Dealer have there ways,but never got an answer as to how they did it.
Your issue is even worse. Hope there is a simple answer.
Radman
Montreal
2014 Audi A6 TDI, 2014 Touareg TDI
I had the same issue last winter and the plastic key broke in the lock. Had to have a towing company come and use an inflatable airbag to pry the door then reach in with a long bar with hook to pull door handle.
compu_85
Gadget Guy
Springfield VA
... None :S
If you turn past the electrical portion, does it engage a mechanical unlock?
I know on B5s, you could backfeed power in through the oil level sensor to try and get power into a locked car. Not sure if that works on the T2...
ADS 55
Chisholm, ACT, 2905
2013 V6 TDi
Hi all,
Any ideas??
Hi. Any further info on this issue? Looks like I have exactly the same problem. Went to move the Touareg after it had been sitting for 2 days and couldn't open the doors. Initially thought it was a flat battery in the key fob. Used my second key fob, no difference. Changed the battery on the key fob - no difference. Removed the plastic manual key and the cover on the door handle - using the manual key was able to turn it ok, but only got a flash of the indicators and a small noise from the door but doors remained locked.
I assume now that it's a flat battery. There is sufficient power to flash the indicators and turn on the park brake light on the dash, but not to actuate the door locks.
A called out the NRMA (that's like road side assist). The mechanic said he couldn't help as door was locked and he had no way to open it without breaking the window.
Called a VW mechanic I use and he advised that as the vehicle was locked with the remote and battery has subsequently died (we assume), then the vehicle is deadlocked. That means even if you break a window, the door won't open from the door handle on the inside.
As I can't get into the vehicle, I can't open the bonnet or access the battery to charge or replace. And we can't tow the vehicle as it is in Park with park brake set.
Any thoughts on how I can open the vehicle and or access the battery to charge it or replace it. I understand that on this model it is located under the left front seat, although I've never accessed it before.
Mike in Anchorage
Anchorage, AK
2016 Touareg Lux, 2015 Golf Sportwagen SE, new 4 Sept 2017;2009 VW Jetta TDI Sportwagen (Ruby) sold to VW on 22 SEP 2017
Watching this thread hoping for reasonable solutions.
Gilty_one
Warman, Saskatchewan, Canada
2016 Touareg Execline 3.0 V6 TDI; 2012 Jetta Highline TDI
Trick. Try to open the rear hatch. For some reason, the designers allow the rear hatch lock to work (motorized door won't work).... then you can crawl through the vehicle to open the doors from the inside. Then you can open the driver's door to pop the hood and get a charger on the battery access points.
I found it annoying that the battery dies in extreme colds - or for when I'm away on extended trips - I plug in a trickle charger under the hood with the cord hanging out.
In my travels I've found that vehicles with the battery installed/mounted under the floorboard or seat seems to have issues when it gets cold. Or maybe its just bad luck on my part.
ADS 55
Chisholm, ACT, 2905
2013 V6 TDi
Found a fix for my problem, Although not sure of the original cause. The remote definitely wouldn't unlock the doors. even with a new battery in the fob key. However, I finally managed to get the plastic manual key to work. Apparently in Australia (righthand drive market), you have to turn the key to the right and keep turning it until you think it's about to snap (ie. past horizontal). This unlocked the door, however the alarm still activated when you open the door. Then you need to put the key fob in the ignition slot. I still had plenty of power in the battery and the alarm stopped and the vehicle started immediately - so there was no flat battery. I still have no idea why the remote stopped working. Since then, I've driived the vehicle a few times and opened and locked it many times with the remote, and no problems. It's a mystery to me why the remote stopped working, but at least i now know how to use the manaual key.
