2013 passat start then dies any hepl ????
rockyw
Miles tx
2013 Passat TDI sel
Any help would be great this car is kicking my a## ! i have triple checked all fuses but no coms from port have tried 4 different scanners i have power and 2 grounds on the pins in the port . it gets exhaust flow out of the exhaust pipe i have pulled egr block off plate off intake . car is deleted malone stage 1.5 no shavings in fuel filter housing or filter none in ip pump fuel is coming out of filter to injection pump i replaced in take fuel pump tach doesn't move when running for few seconds will run at specified rpm with different throttle pedal changes. i don't have vcds lots of lights on in dash cluster 12.7 v at battery i have held battery
cables together for 30 min tried different key fobs ,it popped the intercooler pump fuse which also controls the in tank fuel pump so i changed both is what started this issue i guess?
