2013 oil leak
vwztips
Greenville, SC
2005 Passat GLS Wagon TDI 5 spd manual w/BSM delete 2012 Tiguan TDI/DSG 2005 Audi A4 6MQ 2011 BMW X5 35d
Hello all, have a 2013 Passat TDI with 160k miles. recently developed a decent oil leak on the firewall side. Cannot determine where it is coming from. Underside of turbo is clean.
Any pointers would be appreciated
AaronB
OKC, OK
12 Beater Passat. Real piece
Is it near the passanger side? mine leaked like crazy had to removed cam cradle and reseal it . VW said valve cover gasket but they where wrong.
d2freeman
NC
2013 Passat SE
How bad was it to remove the cam cradle? I believe I have the same leak, although not bad yet, it was not the valve cover or cam seal.
AaronB
OKC, OK
Not that bad. Pull all injectors and pull the valve cover its a slight pain but not bad. i had to make my own injector puller and bought a slide hammer to get them out. i then pinned the cam as if i was doing a timing belt and marked the back gears with sharpies and used a feeler gauge and took 100 reference pics to where teeth lined up and such and pulled them out. i recommened holding the cams in as you pull the craddle off my cam up and then i check cam timing 100000x times lol. But i just sealed it up and reversed the process. the cam without a pin has the vac pump slot that needs to be parallel with the head so the slot sits at 9 and 3 o'clock.
AaronB
OKC, OK
I also changed the cam seal and now i dont have a single leak. my car used to smoke when it would regen because the dpf got so hot and would burn off that oil on the back of the block. i eventually did a delete to help the issue put the oil leak made me mad so i dove in and fixed it.
d2freeman
NC
2013 Passat SE
Getting ready to do the reseal on the cam cradle and have a couple of questions.
Did you have to remove the cams or just remove the cradle and leave them in place?
And did you have to remove the vacuum pump?
