2013 Jetta TDI - 006744 - NOx Catalyst P1A58 - 000 - Regeneration Required - measured zoot zero
kraftwerkturbo
Brighton, MI
2005 Golf 1.9 TDI auto
Have the above code. Can only find info on "DPF regen". But read that measured zoot should be 45 or below for driving regen and 35-40 for stationary regen (group 241 or 108). Tried security login 27971 for stationary regen, basic settings, regen DPF while standing. Getting Error.
Is "DPF regen" different from "NOx cat regen"?
If so: how do do a NOx cat regen (as code requires)?
If not: what can I do the run regen even so measured zoot values don't seem to 'qualify', yet, getting NOx code?
Dannyboy
Mb
NOx regen and DPF regen are two different modes but both are very similar in the way they work. However NOx regen gets the exhaust much hotter than usual dpf regen.
"NOX regen while driving" should be under adaptations on VCDS. It's been awhile so not 100%.
Make sure there's no emissions or engine faults (other than Nox regen required code) make sure you have over half a tank of fuel and a good straight stretch of road that has a speed limit over 50 mph. Last time in needed to do one on a 2010 golf it took 30 mins to complete.
kraftwerkturbo
Brighton, MI
Will get full scan and see if I find "NOX regen" somewhere else (not in basic settings, but adaptions?). Was hoping to have 'stationary' option as with DPF regen so I can do the regen this weekend (and not having to drive 1 hour in 6 inches of snow at 2000 rpm).
Seatman
Scotland
2014 Skoda rapid elegance 1.6 cr tdi
Looks like you need to do a long drive, it sounds like the car isn't being driven long enough for the cat to do it's regen too
If you glance through this thread it talks about needing a long drive
And this this link suggests 40-75mph, needs the engine fully warmed up then the actual regen takes 40-50 minutes of sustained driving. That's for the cat regen.
But it also sounds like you're having to crappy weather to manage it just now.
kraftwerkturbo
Brighton, MI
Friday,12,January,2024,14:23:14:03761
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 23.11.0.0 (x64)
Data version: 20231027 DS351.0
www.Ross-Tech.com
VIN: 3VWPL7AJ2DM615266 License Plate:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 37 42 44 46 4F 52 56
62 72
VIN: 3VWPL7AJ2DM615266 Mileage: 204980km-127368miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 997 030 E HW: 03L 907 309 AA
Component: R4 2.0l TDI G000AG 9983
Revision: 12H15--- Serial number:
Coding: 0050078
Shop #: WSC 45097 002 1048576
VCID: 306E9D27A32DE21173-8064
VINID: 0E69E070745A094746045086182432849F
1 Fault Found:
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 2
Reset counter: 255
Mileage: 204983 km
Time Indication: 0
Date: 2018.06.03
Time: 20:21:52
Freeze Frame:
RPM: 828 /min
Speed: 0.0 km/h
Load: 0.0 %
Pressure: 968.0 mbar
Temperature: 0.9°C
Mass Air / Rev.: 270.0 mg/str
Temperature: 7.2°C
Readiness: 0 0 0 1 1
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 062 B HW: 02E 927 770 AL
Component: GSG DSG AG6 512 9430
Revision: 05551213 Serial number: 00001206151623
Coding: 0000020
Shop #: WSC 00066 000 00000
VCID: 142631B737753E3177-8040
No fault code found.
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
Coding: 114B600C492300FF880D06EA921F0042B70000
VCID: 7DF07413E4FFDF79A8-8028
Address 05: Acc/Start Auth. (J518) Labels:| 5K0-959-434.clb
Part No SW: 5K0 959 434 B HW: 5K0 959 434
Component: VWKESSYPQ35GP 085 0902
Revision: 00085000 Serial number: 0169724323 Dataset Number: 5K0116v____ 1K07
Coding: 030C0C
ASAM Dataset: EV_KESSYPQ35G A02013
ROD: EV_KESSYPQ35G_A02_VW31.rod
VCID: 346691379F35DE3117-8060
Address 08: Auto HVAC (J301) Labels:| 3C8-907-336.clb
Part No SW: 7N0 907 426 BH HW: 7N0 907 426 BH
Component: AC Manuell H20 0505
Revision: 00001018
Coding: 0010002002
Shop #: WSC 00066 000 00119
ASAM Dataset: EV_ACManueBHBVW36X A01010
ROD: EV_ACManueBHBVW36X_VW36.rod
VCID: 7BF47A0BF2EBD14996-802E
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 5K0 937 084 J HW: 5K0 937 084 J
Component: BCM PQ35 B 021 3068
Revision: BG021001
Coding: 6F380E1F802F3EC4008800C17000004449000086575D05F064802020A040
VCID: 3978A003B0572359C4-806C
Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 03081 26 0512
Coding: 009795
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 5C0 959 655 M HW: 5C0 959 655 M
Component: AirbagVW10G 014 0726
Serial number: 003L4R0062S5 Dataset Number: 1KM003v__B_ 0047
Coding: 00004E42
Shop #: WSC 00066 790 00083
ASAM Dataset: EV_AirbaVW10SMEVW360 001026
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3C76B917B7651671DF-8068
Seat occupied recognition:
Subsystem 1 - Part No SW: 1KM 959 339 B HW: 1KM 959 339 B
Component: BF-Gewichtss. 006 0001
Serial number: ---0000R--00005AJA00
Crash sensor for side airbag: driver side:
Subsystem 2 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Component: S.Sens.Fahr.V H02 ----
Serial number: 3572MSME68564571ZZZZ
Front Passenger's Side Airbag Crash Sensor:
Subsystem 3 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Component: S.Sens.Beif.V H02 ----
Serial number: 3582MSME34584571ZZZV
Rear Side Airbag Crash Sensor (on driver's side):
Component: S.Sens.Fahr.H --- ----
Serial number: 3511HSME506F0F2EZZZ
Passenger side rear thorax airbag crash sensor:
Component: S.Sens.Beif.H --- ----
Serial number: 3521HSME3E710E2EZZZ.
Crash sensor for front airbag: driver side:
Component: F.Sens.Fahr --- ----
Serial number: 35527SME0372002EZZZ4
Crash sensor for front airbag: front passenger side:
Component: F.Sens.Beif --- ----
Serial number: 35627SME7242012EZZZ9
Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
Part No SW: 5K0 953 521 BR HW: 5K0 953 569 E
Component: LENKS.MODUL 014 0140
Revision: FF010041 Serial number: 20120712200688
Coding: 100A140000
ASAM Dataset: EV_SMLSNGVOLWSXS A01004
ROD: EV_SMLSNGVOLWS.rod
VCID: 7DF07413ECFFDF79A8-8028
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H09 0013
Coding: 820000
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 5K0 920 973 C HW: 5K0 920 973 C
Component: KOMBI H05 0705
Serial number: 00000000000000
Coding: 270F01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04716
ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
VCID: 316898236027EB197C-8064
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 T HW: 7N0 907 530 K
Component: J533 Gateway H40 1632
Revision: H40 Serial number: 02061201290404
Coding: 352002
VCID: 4188C8E3D8877B998C-8014
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H05 0705
Serial number:
Coding: 000007
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03709
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6ADA4F4F8D7158C17D-803E
Address 2B: Steer. Col. Lock (J764) Labels:* 5K0-905-861.clb
Part No SW: 5K0 905 861 B HW: 5K0 905 861 B
Component: ELV-PQ35 H20 0240
Revision: 00000000 Serial number: 12000142695005
Coding: 4900000000000000
Shop #: WSC 00066 790 50316
ASAM Dataset: EV_ELVMarquMPVW36X A01001
ROD: EV_ELVMarquMPVW36X.rod
VCID: 2F6C9E5B7613FDE96A-807A
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H18 0530
Revision: A1001003 Serial number: 7662932362
Coding: 020100
VCID: 2A5A8F4F45F198C1BD-807E
Address 37: Navigation (J794) Labels:| 1K0-035-27x-37.clb
Part No SW: 1K0 035 274 D HW: 1K0 035 274 D
Component: RNS315-NAR H53 0319
Serial number: VWZAZ2M4241847
Coding: 04000401040007000000100A
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_RNS315NARV2UDS 001705
ROD: EV_RNS315NARV2UDS.rod
VCID: 25407C7324EFB7B990-8070
Data carrier:
Subsystem 1 - Part No: 3AA 919 866 B
Component: NAR_V3_(0037) 0037
1 Fault Found:
1048669 - Tuner for Satellite Radio
B11CF 53 [00001001] - Deactivated
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 171
Mileage: 202648 km
Date: 2023.12.09
Time: 16:54:41
Address 42: Door Elect, Driver (J386) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 561 959 701 HW: 3C0 959 793 B
Component: TUER-SG FT 002 0501
Revision: 13110009 Serial number: 0005190602
Coding: 0004B5
ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
ROD: EV_TSGFPQ35BRFVW46X_VW36.rod
VCID: 5BB41A8B522B3149F6-800E
Slave Driver:
Subsystem 1 - Part No SW: 3C0 959 703 C HW: 3C0 959 795 D Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 008 1509
Serial number: 00000006984709
Coding: 000490
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 70 3305
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 377CA63B4643352932-8062
Address 4F: Centr. Electr. II (J520) Labels:. 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 7N0 907 530 K
Component: EZE_2 H40 1632
Coding: 050B0500
VCID: 6FEC5E5BBE93BDE92A-803A
Subsystem 1 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H03 0220
Serial number: 0123456789ABCDEFGHIJ
Subsystem 2 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE20SKB13 H03 0220
Address 52: Door Elect, Pass. (J387) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 561 959 702 HW: 3C0 959 792 B
Component: TUER-SG BT 002 0501
Revision: 15110009 Serial number: 0005146292
Coding: 0004B4
ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
ROD: EV_TSGBPQ35BRFVW46X_VW36.rod
VCID: 5CB6199757253671FF-8008
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 704 C HW: 3C0 959 794 D Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 008 1509
Serial number: 00000006896914
Coding: 000490
End-------------------------(Elapsed Time: 03:29)--------------------------
Seatman
Scotland
Looks NOx regen only with driving.
Possible that it clears itself IF taken on a long drive? Or does it have to be 'activated' via Rosstech in Adaption?
It sounds like it's a long drive only for the cat, first it has to reach a high enough temp then it should start burning the stuff up.
If the coolant drops below about 90C, it won't ever do the deNOX catalyst regen. Drive it and see.... these often need thermostats to allow a fix. You can initiate a manual regen while driving, but it will fail if the coolant temp isn't sufficient.
Arrbees
USA
2011 Jetta TDI
Made an account just to reply in layman's terms here.
There's two separate regens. The DPF regen is the most common one. Usually you may hear the fans running and get a nice power boost during the DPF regen. It's pretty brainless and requires no effort.
The cat also regens as others have already stated, which I don't recall seeing in the car's manual anywhere BTW. This is a much less common regen and I think my first one was needed well into the 4th year I owned the car since I don't drive much.
You may have heard the high fan cycle often for a couple days. It may be going off and on in stop and go traffic. You probably have the cheese grater light on the dash, meaning it's been trying to regen the cat and failed several times likely due to the vehicle being shut off.
That simply means it's time for a nice long drive on the highway. Plan to drive about 15 to 25 continuous minutes one way. Seems to work best if you can go about 70mph although there's no need to exceed the speed limit if that's not possible since it will happen eventually anyway.
No scan tool or special process is needed. Although it is handy to have one plugged to ensure the coolant temp gets high enough if not you may need to replace the thermostat, which I hear can be a common problem on the MK6 TDIs plus it's in an absolutely terrible location (yay). If there's an issue with the thermostat in winter you may be able to employ radiator blocking as a temporary work around until it's warm enough to tear the whole front of the engine bay out to get to the thermostat.
Anyway, drive on the highway after the vehicle is at operating temperature until the cheese grater light goes out. If it comes back on the next day do it again. After my most recent cat regen I think it's probably ideal to continue driving for at least 20 minutes after the light goes out to avoid having it come back on.
kraftwerkturbo
Brighton, MI
Want to do the NOx regen while driving today. What are the securit codes? I think the NOx is in Adaption (while the DPF is in in another section)?
kraftwerkturbo
Brighton, MI
Entered the sec code 12233 in adaption, block 18 (NOx regen). Entered 1 in "new value", "Test", Save. Then drove at 2200 rpm, 5th gear,. 64 mph steady foreever (more than 50 min). Don't know what the starting values were, but it settled for 3.27 NOx load and 3.0 calculated Soot value. Dash warning light and error code gone.
Not impressed with the process. Can't they show 'progress'? What is the end value supposed to be? Did it even work?
JonA
Rhode Island
2002 Golf TDI M/T
I know this is an older thread but I saw this info in OBDEleven to check NOX regen status @kraftwerkturbo: under Engine - live data - channel 104 - the block 1 value (if I recall correctly) changes to 0x0FF02 when the NOX regen is done. Will take a screenshot and update this post later for future visitors.
Was just poking around for further info on the NOX regen because MVB 104.1 flipped through a couple values for me, from 0x0FF20, ending at 0x0FF01 and I'm wondering what that means... Going to give it another go tonight and hopefully it will flip to 0x0FF02 finally...
I have found that those MVB 104/1 values don't seem to coincide with what you'd expect. Because I've had them get to '02' and you think it has finished, and then the next day the warning lamp has returned.... then doing nothing but driving it and the warning lamp goes out, and all the readiness is set.
So....
But I always, ALWAYS, drive the car and monitor the coolant temp. Because a marginal thermostat often causes this. There is a TSB about it. If it can't stay 92C+, it is bad. The TSB says it must not go below 87C, but I just know after replacing the thermostat they are generally able to stay well above that.
JonA
Rhode Island
2002 Golf TDI M/T
So....
As always, very much appreciate your input oilhammer! Will be sure to monitor that when I give it another go.
0x0FF20 is SOX regen (Bit 5 active) 0010 0000b
Thank you KERMA! Based on that, I'm guessing that I didn't let the NOX regen cycle fully finish despite running at the specified speed/RPM for 50+ mins. Is there a legend somewhere that'll help me decode the other values?
JonA
Rhode Island
2002 Golf TDI M/T
Amazing, somehow managed to avoid finding your post in all my searching, ha. Thanks so much, going to read through that thread later tonight. How did you learn this?!
Edit: forgot who I was talking to 😆
tdb1980
San Antonio
Passat, Jetta
Dusting off this old thread. I was experiencing the same nox regen light and error code. Thanks to the above experts for providing some helpful hints. Drove about 30 mins and forced a Regen with vcds. Light is gone. Cheers to this community!
KarmaKeeper
CentralCoast, CA
12' Passat, 12' Jetta; 11' Jetta
Would like to add yes another thank you for contributors to this P1A58 thread, also have a CJAA with a P1A58 in constant 'EXHAUST COOKING ITSELF LOOP' for a few hundred miles. TSB link was a great help. Just did a 20 min drive while monitoring coolant temp never got above 83C, why keep driving - right. Will add and edit if thermostats replacement finally stops the regen cycle loop. To be continued!
BIGGUN
St Louis Mo
2013 Jetta TDI
Hello everyone, I'm new to the TDI world and I just wanted to thank you for all of the info that you've shared. I purchased the vcds cable and should receive it today. I'll update this post with the results after attempting to regen.
KarmaKeeper
CentralCoast, CA
Updated with result - replaced thermostat [fun job ; ) ] - car climbed to normal operating temp monitored it at 95-100C. The NOx Catalyst Regen completed on its own after a 20 minute drive! Readiness finally achieved, thanks again.
I would agree with a lot of other threads that this thermostat issue is probably what is cracking a lot of the DPF's, it literately COOKS your exhaust over and over in this scenario.
