2013 Golf TDI limp mode
bowelder
south carolina
2013 VW golf TDI with tech package
I need help diagnosing what's causing my limp mode condition. My wife drove over a limb at a friend's house and now I'm in limp mode. Could be totally coincidental, but i now have code P0299. Here is my current scan below.
thanks a ton
16683/P0299/000665
Jump to:navigation, search
Contents
16683/P0299/000665 - Boost Pressure Regulation: Control Range Not Reached
Possible Symptoms
  • Reduced Power Output
  • Limp Mode
Possible Causes
  • Hoses/Pipes incorrect connected, disconnected or leaking
  • Charger Pressure Control defective
  • Turbocharger faulty
  • Diverter Valve faulty
Possible Solutions
  • Check Hoses/Pipes to/between Components
  • Check / Clean / Replace Charge Pressure Control
  • Check Turbocharger
  • Check Diverter Valve
Special Notes
  • If the Turbocharger is faulty due to mechanical / internal problems or the exhaust system is restricted (typically the Catalyst) this fault may be the end result.
Gasoline
  • When found in 2.0l TFSI:
    • Check Boost Pressure Control Valve (N249), for cracked rubber diaphragm. A new/optimized Valve is available, see parts catalog.
    • When stored in conjunction with misfire codes and/or fuel trim faults see the notes associated with the following faults regarding PCV failure: P2279, P1136, P1297, P1093 and/or P0507.
  • When found in 2009-2012 Audi with CAEB engine:
  • When found in All 2008 to 2015 Volkswagen vehicles with the 2.0L TSI Engines (codes CCTA and CBFA)
    • See Volkswagen Tech Tip 21-10-02.
      • https://static.nhtsa.gov/odi/tsbs/2015/MC-10122981-9999.pdf NHTSA
      • This Tech Tip suggests to check if the wastegate valve and lever has dropped and become stuck/seized causing either an over-boost or under-boost fault. P0299, P0234 or P0236.
      • This concern can be intermittent also clearance between the turbocharger housing and the wastegate lever should be about 3.0mm.
Diesel
  • 2009-2014 VW NAR with 2.0 CR-TDI (CBEA/CJAA), TSB 21-14-03 or TPI 2026771 has several items to inspect and verify to factory design.
  • When found in VW Golf/Jetta (1K): 2.0l CR-TDI (CBEA/CJAA).
    • Verify the mechanical part of the Exhaust Valve Control Module (J883) is not seized or binding.
  • When found in the 1.9 L TDI-PD (BLS):
    • Check vacuum supply from the vacuum reservoir located in the valve cover for leaks. Using a vacuum gauge, wiggle the valve cover and hose connections to check for a leak. The following photo was submitted from a customer working on a 2010 VW Caddy (2K chassis) with this vacuum reservoir problem.
"CODE" Sunday,10,September,2023,13:52:59:21907
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86
VCDS Version: 23.3.1.0 HEX-V2 CB: 0.4631.4
Data version: 20230421 DS346.2
www.Ross-Tech.com
VIN: WVWDM7AJ3DW136437 License Plate:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 37 42 44 46 47 52 55
56 62 72
VIN: WVWDM7AJ3DW136437 Mileage: 212370km-131960miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: Sporadic communication error 1000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
2B-Steer. Col. Lock -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 1010
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 997 030 E HW: 03L 907 309 AA
Component: R4 2.0l TDI G000AG 9983
Revision: 12H15--- Serial number:
Coding: 0050078
Shop #: WSC 34209 003 1048576
VCID: 30390355A6260ABABFB-8064
VINID: 9E69D474745A0D49C10C61031C2EB7F7B0
6 Faults Found:
011174 - NOx Emissions Exceeded
P2BA6 - 000 - SCR Catalyst Malfunction
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 212374 km
Time Indication: 0
Date: 2018.01.31
Time: 01:15:23
Freeze Frame:
RPM: 828 /min
Speed: 0.0 km/h
Load: 0.0 %
Pressure: 980.1 mbar
Temperature: 30.6°C
Mass Air / Rev.: 260.0 mg/str
Temperature: 36.9°C
006744 - NOx Catalyst
P1A58 - 000 - Regeneration Required - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 255
Mileage: 212374 km
Time Indication: 0
Date: 2018.01.31
Time: 01:15:23
Freeze Frame:
RPM: 828 /min
Speed: 0.0 km/h
Load: 0.0 %
Temperature: 30.6°C
Temperature: 36.9°C
008213 - Intake Manifold Flap Position Sensor (Bank 1)
P2015 - 003 - Implausible Signal
Freeze Frame:
Fault Status: 01100011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 212374 km
Time Indication: 0
Date: 2018.01.31
Time: 01:15:23
Freeze Frame:
RPM: 828 /min
Speed: 0.0 km/h
Voltage: 13.76 V
Lambda: -7.9 %
Lambda: 6.3 %
Bin. Bits: 00000000
Voltage: 0.304 V
008200 - Intake Manifold Flap; Bank 1
P2008 - 000 - Electrical Malfunction - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 19
Reset counter: 255
Mileage: 212374 km
Time Indication: 0
Date: 2018.01.31
Time: 01:17:42
Freeze Frame:
RPM: 805 /min
Speed: 0.0 km/h
Load: 0.0 %
Load: 11.0 %
Lambda: 99.4 %
Mass Air / Rev.: 225.0 mg/str
Temperature: 73.8°C
P0299 - 000 - Control Range Not Reached - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 212375 km
Time Indication: 0
Date: 2018.01.31
Time: 01:20:04
Freeze Frame:
RPM: 2323 /min
Speed: 31.0 km/h
Load: 54.9 %
Pressure: 2081.2 mbar
Pressure: 883.3 mbar
Lambda: 91.5 %
Lambda: 90.7 %
P0299 - 001 - Control Range Not Reached
Freeze Frame:
Fault Status: 01100001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 212375 km
Time Indication: 0
Date: 2018.01.31
Time: 01:20:04
Freeze Frame:
RPM: 2323 /min
Speed: 31.0 km/h
Load: 54.9 %
Lambda: 91.5 %
Lambda: 90.7 %
Readiness: 0 0 0 0 1
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 062 B HW: 02E 927 770 AL
Component: GSG DSG AG6 512 9430
Revision: 05651213 Serial number: 00001303260612
Coding: 0000020
Shop #: WSC 01357 011 00200
VCID: 1471AFC5327ED69ABB3-8040
1 Fault Found:
18036 - Powertrain Data Bus
P1628 - 000 - Missing Message from Steering Angle Sensor - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 59
Reset counter: 21
Mileage: 208591 km
Time Indication: 0
Date: 2017.12.17
Time: 03:14:14
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
Coding: 114B400C49250000880F02E792200042B70000
VCID: 7DA7EA612DF437D264D-8028
3 Faults Found:
01309 - Power Steering Control Module (J500)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 14
Reset counter: 173
Mileage: 206450 km
Time Indication: 0
Date: 2017.11.17
Time: 03:26:47
Freeze Frame:
Count: 0
Count: 32768
Count: 4608
Count: 8213
Count: 47873
Count: 0
Count: 253
Count: 0
00778 - Steering Angle Sensor (G85)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 10
Reset counter: 173
Mileage: 208591 km
Time Indication: 0
Date: 2017.12.17
Time: 03:14:10
Freeze Frame:
Count: 2
Count: 32768
Count: 4608
Count: 166
Count: 47618
Count: 1
Count: 1021
Count: 0
01325 - Control Module for Tire Pressure Monitoring (J502)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 10
Reset counter: 173
Mileage: 208591 km
Time Indication: 0
Date: 2017.12.17
Time: 03:14:20
Freeze Frame:
Count: 2
Count: 32768
Count: 4608
Count: 16390
Count: 47874
Count: 1
Count: 513
Count: 0
Address 05: Acc/Start Auth. (J518) Labels:| 5K0-959-434.clb
Part No SW: 5K0 959 434 B HW: 5K0 959 434
Component: VWKESSYPQ35GP 086 1101
Revision: 00086000 Serial number: 0211310023 Dataset Number: 5K0116v____ 5K0C
Coding: 030C0C
ASAM Dataset: EV_KESSYPQ35G A02013
ROD: EV_KESSYPQ35G_A02_VW31.rod
VCID: 34310F455EBE369ADB3-8060
No fault code found.
Address 08: Auto HVAC (J301) Labels:| 3C8-907-336.clb
Part No SW: 7N0 907 426 BH HW: 7N0 907 426 BH
Component: AC Manuell H20 0505
Revision: 00001018
Coding: 0010002002
ASAM Dataset: EV_ACManueBHBVW36X A01010
ROD: EV_ACManueBHBVW36X_VW36.rod
VCID: 7BA3E479336039E25A9-802E
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 1K0 937 086 T HW: 1K0 937 086 T
Component: BCM PQ35 M 111 0717
Revision: AC111709
Coding: 6F180A1A90272AC4108800C170008D4448852086574D85B0E48420248040
Shop #: WSC 08436 003 1048576
VCID: 41DF5691118C9332405-8014
Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 08041 26 0512
Coding: 009795
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 82
Reset counter: 173
Mileage: 208591 km
Time Indication: 0
Date: 2017.12.17
Time: 03:14:14
Freeze Frame:
Term 15 On
Voltage: 13.10 V
ON
ON
Term 50 Off
OFF
OFF
Freeze Frame:
Fault Priority: 6
Fault Frequency: 66
Reset counter: 173
Mileage: 208591 km
Time Indication: 0
Date: 2017.12.17
Time: 03:14:23
Freeze Frame:
Term 15 On
Voltage: 13.15 V
ON
ON
Term 50 Off
OFF
OFF
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 5C0 959 655 M HW: 5C0 959 655 M
Component: AirbagVW10G 014 0726
Serial number: 003L4R01UEFT Dataset Number: 5K0003v__B_ 0080
Coding: 00004737
ASAM Dataset: EV_AirbaVW10SMEVW360 001026
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3C21276576EEFEDA133-8068
Seat occupied recognition:
Subsystem 1 - Part No SW: 5K0 959 339 B HW: 5K0 959 339 B
Component: BF-Gewichtss. 006 0001
Serial number: ---0000R--00006T9A00
Crash sensor for side airbag: driver side:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H02 ----
Serial number: 3572MSME54135578ZZZV
Front Passenger's Side Airbag Crash Sensor:
Subsystem 3 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V H02 ----
Serial number: 3582MSME494F5577ZZZ7
Rear Side Airbag Crash Sensor (on driver's side):
Component: S.Sens.Fahr.H --- ----
Serial number: 3512QSME5E0A2F49ZZZ7
Passenger side rear thorax airbag crash sensor:
Component: S.Sens.Beif.H --- ----
Serial number: 3522QSME7C392C76ZZZ7
Crash sensor for front airbag: driver side:
Component: F.Sens.Fahr --- ----
Serial number: 35527SME6425532FZZZI
Crash sensor for front airbag: front passenger side:
Component: F.Sens.Beif --- ----
Serial number: 35627SME5E27532FZZZU
Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
Part No SW: 5K0 953 521 BR HW: 5K0 953 569 E
Component: LENKS.MODUL 016 0140
Revision: FF010041 Serial number: 20130409301586
Coding: 101A140000
ASAM Dataset: EV_SMLSNGVOLWSXS A01004
ROD: EV_SMLSNGVOLWS.rod
VCID: 7DA7EA612D7437D264D-8028
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D Labels: 3C8-959-537.CLB
Component: E221__MFL-TK6 H07 0022
Coding: E30000
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 5K0 920 973 C HW: 5K0 920 973 C
Component: KOMBI H05 0705
Serial number: 00000000000000
Coding: 270F01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04716
ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
VCID: 313F0651A1AC03B2B05-8064
1 Fault Found:
13638912 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Steuergerät für Lenkhilfe: keine Kommunikation]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 112
Reset counter: 173
Mileage: 208591 km
Date: 2023.07.27
Time: 03:14:12
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 AF HW: 7N0 907 530 AF
Component: J533 Gateway H52 1634
Revision: H52 Serial number: 310313F1000849
Coding: 350002
VCID: 74B1CF451EBE769A1B3-8020
2 Faults Found:
Freeze Frame:
Fault Status: 00110100
Fault Priority: 2
Fault Frequency: 116
Reset counter: 173
Mileage: 208591 km
Time Indication: 0
Date: 2017.12.17
Time: 03:14:15
Freeze Frame:
Fault Priority: 2
Fault Frequency: 113
Reset counter: 173
Mileage: 208591 km
Time Indication: 0
Date: 2017.12.17
Time: 03:14:14
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H05 0705
Coding: 000007
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03709
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6A8DD13D4CFAB06AB1F-803E
1 Fault Found:
9456128 - Engine Control Module (ECM) not authorized
B104A 00 [008] - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 2
Address 2B: Steer. Col. Lock (J764) Labels:* 5K0-905-861.clb
Part No SW: 5K0 905 861 C HW: 5K0 905 861 C
Component: ELV-PQ35 H21 0240
Revision: 00000000 Serial number: 13000041325002
Coding: 4900000000000000
ASAM Dataset: EV_ELVMarquMPVW36X A01001
ROD: EV_ELVMarquMPVW36X.rod
VCID: 30390355AAA60ABABFB-8064
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H19 0550
Revision: A1001003 Serial number: 7664604269
Coding: 020100
VCID: 2A0D113D8CFA706A71F-807E
Address 37: Navigation (J794) Labels:| 1K0-035-27x-37.clb
Part No SW: 1K0 035 274 E HW: 1K0 035 274 E
Component: RNS315-NAR H62 0319
Serial number: VWZAZ2P0207381
Coding: 00000401010000000000000A
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_RNS315NARV2UDS 001705
ROD: EV_RNS315NARV2UDS.rod
VCID: 2615E50D9862540A557-8072
Data carrier:
Subsystem 1 - Part No: 3AA 919 866 B
Component: NAR_V3_(0037) 0037
6 Faults Found:
1048593 - Front Left Bass Speaker
B105F 13 [009] - Open Circuit
[woofer front left open load]
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 39
Mileage: 197045 km
Date: 2023.03.14
Time: 23:42:36
1048594 - Front Right Bass Speaker
B1062 13 [009] - Open Circuit
[woofer front right open load]
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 39
Mileage: 197045 km
Date: 2023.03.14
Time: 23:42:36
1048595 - Rear Left Bass Speaker
B1065 13 [009] - Open Circuit
[woofer rear left open load]
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 39
Mileage: 197045 km
Date: 2023.03.14
Time: 23:42:36
1048596 - Rear Right Bass Speaker
B1067 13 [009] - Open Circuit
[woofer rear right open load]
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 39
Mileage: 197045 km
Date: 2023.03.14
Time: 23:42:36
1048669 - Tuner for Satellite Radio
B11CF 53 [009] - Deactivated
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 39
Mileage: 197045 km
Date: 2023.03.14
Time: 23:42:34
1048640 - Control module not coded
U1013 00 [009] - -
[ECU not coded]
Freeze Frame:
Fault Priority: 3
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb
Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
Component: Tuer-SG 009 2119
Coding: 0001204
VCID: 313F0651AD2C03B2B05-8064
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 70 3305
Revision: 00H22000
VCID: 372B38494348DD82FE1-8062
2 Faults Found:
01312 - Powertrain Data Bus
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 4
Fault Frequency: 74
Reset counter: 173
Mileage: 211509 km
Time Indication: 0
Date: 2018.01.19
Time: 03:39:02
Freeze Frame:
Voltage: 13.13 V
DU
Temperature: 54.0°C
RPM: 1498 /min
Speed: 75.0 km/h
Speed: 50.0 km/h
Count: 3
01316 - ABS Control Module
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 173
Mileage: 211509 km
Time Indication: 0
Date: 2018.01.19
Time: 03:39:02
Freeze Frame:
Voltage: 13.13 V
DU
Temperature: 54.0°C
RPM: 1498 /min
Speed: 77.0 km/h
Speed: 77.0 km/h
Count: 2
Address 47: Sound System (R12) Labels: 5K0-035-456.clb
Part No SW: 5K0 035 456 B HW: 5K0 035 456 B
Component: KonzernAmp 8K H07 0368
Revision: -------- Serial number: EAA085A0062012 Dataset Number: 1K8050v____ 5K04
ASAM Dataset: EV_AudioVerst8KanalBNO1 A01003
ROD: EV_AudioVerst8KanalBNO1.rod
VCID: 290FEE31897C7B72785-807C
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
Coding: 0001204
VCID: 323D095DA82A38AAC9F-8066
Address 55: Headlight Range Labels: 5M0-907-357-V2.clb
Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
Component: AFS-Steuergeraet 0148
Revision: 00H04000 Serial number:
Coding: 1446940
VCID: 34310F45523E369ADB3-8060
Subsystem 1 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l 0004
Coding: 00000022
Subsystem 2 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul r 0004
Coding: 00000022
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 254
Reset counter: 173
Mileage: 208591 km
Time Indication: 0
Date: 2017.12.17
Time: 03:14:14
Freeze Frame:
Voltage: 13.06 V
Speed: 111.8 km/h
ABS 1
Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
Part No SW: 5K0 959 703 D HW: 5K0 959 703 D
Component: Tuer-SG 007 2101
Coding: 0001168
Shop #: WSC 01357 011 1012552
VCID: 3537324159442F92ECD-8060
pkhoury
That guy with the goats
Medina, TX
I could be wrong, but some of those codes almost seem to imply new DPF time.
So since you have the codes saved, what I'd do is clear everything, and take it for a test drive, and see if the codes come back as well.
The other codes make me think the battery was simply disconnected at some point, but this is only based on personal experience.
Canary5.0
Missouri
2012 Golf DSG w/ Tech Pkg. Malone Stage II
Have you been able to check for damage under the car? It mentions exhaust restriction in the code explanation. Maybe a catalyst, resonator, or the muffler is crushed or even the pipe itself
Wilkins
British Columbia
I wouldn’t be surprised if you have wiring damage issues. The codes for ABS, steering angle etc point that way.
Would you mind editing your post to put the scan data inside CODE tags? That means inserting <code> before the scan text and </code> after the scan text. Doing so makes your post so much easier to read and will probably get you better responses.
bowelder
south carolina
When you say DPF time, are you referring to forcing a regen with the VCDS?
pkhoury
Medina, TX
Getting it replaced, not forcing a regen.
At this point, you already have your codes saved. I'd clear them and see what comes back.
pkhoury
Medina, TX
I’m thinking if it needs replacing, I may opt for a deletion and tune
I won't disagree, but in the meantime, it doesn't hurt to clear the codes just to see what comes back, to kinda confirm what's broken.
That said, I'm all for a delete. SOOOO many problems eliminated as a result. The DPF and EGR is inherently flaky, and like Nissan's CVTs, it's not if it will fail, it's WHEN.
bowelder
south carolina
So I have the VCDS and looking through basic settings, what does a basic setting mean when it says “adaptation”?
wonneber
Monroe, NY, USA
If you have to much $$$ you could just guess at what to try but somehow I don't thing you do. :)
Why not try the suggestion of clearing the codes?
Shut the car after clearing and let it stay off for a while.
See what comes back. :)
Just my $0.02 (US)
bowelder
south carolina
Just my $0.02 (US)
I did that, and these 2 codes come back
011174 NOx Emissions exceeded
P2BA6-000 SCR Catalyst Malfunction
006744 NOx Catalyst
P1A58-000 Regeneration required
that’s just idling in the driveway
