2012VWJ
anyone know what that tiny bulb is called next to your high and low beam light ? And how to replace it ?
Just a warning, you have to watch the polarity if you go LED.They're called "city lights".
Someone over at the Vortex posted a how-to on swapping to LEDs, but the same basics would apply if you just wanted to replace (although I'd go LED).
Lots of the newer, better LEDs (think $25 for a pair instead of $5/pair) have built-in resistors (typically advertised as "CANBUS") as well as being polarity-agnostic. The LED brake lights (Oxilam and KaTur are the brands I've gone with) on my Mk7 (7440 bulbs) tails are like that - no need to pay attention to which way they're inserted, and the car doesn't throw any codes.Just a warning, you have to watch the polarity if you go LED.
If you power it backwards it's instantly toast.
If I recall correctly the longer lead is + but check the package indicates otherwise.
You also need a resister to drop the voltage to the lights voltage.
One for each again.
Nuje, thanks for the feedback.Lots of the newer, better LEDs (think $25 for a pair instead of $5/pair) have built-in resistors (typically advertised as "CANBUS") as well as being polarity-agnostic. The LED brake lights (Oxilam and KaTur are the brands I've gone with) on my Mk7 (7440 bulbs) tails are like that - no need to pay attention to which way they're inserted, and the car doesn't throw any codes.
