TDIMikeMN
so...DRL bulb is flickering so not sure it is going.. or just loose.
How tough is it to get at these? What needs to be taken apart? Thanks
I found it much easier and less frustrating to pull the entire housing rather than go through the wheel well access. 2050 miles and my right DRL bulb filament cracked right where it is crimped into the holder within the glass ampule that is the bulb. I was able to see it spark when flicking the bulb while hooked up to a battery charger. At least the MFA was kind enough to tell me to check the RF DRL.
Anyways, the way provided by VW is to turn the front wheel inward on the side that you want to access the DRL, open the little hatch that is held on with a T25 screw, reach in and under the headlamp housing and then contorting yourself further give the cap on the bottom of the housing a 1/4 turn to disengage the tabs. Now the fun part. Reach in there and with 2 fingers (which is all you can grab with) twist the carrier a 1/4 turn and pull it from within and out of the housing. Now the really fun part - since the wire connecting the socket is only so short, you have to remove the old bulb with one hand and then the PITA part, snap the new bulb back into the bulb holder with one hand (yes it can be done) and then the really, really PITA part is to get the bulb and holder back into the housing and hope that you can do it. After I popped the bulb off inside the DRL compartment, I figured there had to be a better (and easier) way. I simply removed the headlamp housing - 7 screws with a T30 bit. You have to remove the 3 T25 screws on the top of the grill and then grasping the grill firmly in the bottom slot, pull it straight out. The headlamp housing simply lifts out and it was a breeze to shake the loose bulb out and then thread and lock the @%$@(*$ bulb holder into place. After almost an hour of getting very frustrated with the VW way, 15 minutes was all it took to remove and replace the entire housing. Well worth the little extra effort and much, much less frustrating. Trust me, I know, especially if you got big hands like me. If you're going to upgrade or LED your DRL's you'll be glad you pulled the housings.
See this drawing of the housing - #14 is the DRL, the round disc is the access cap. Good Luck!
Pretty sure were talking about super stealth internet license plate hooligans here. :roll eyes:Not sure how a license plate will advantage an evildoer. All they have to do is drive down the highway and write them down.
