Fastbird
Someone just double check me for my sanity. I purchased a kit on ebay, the RGB kit, for my car. Install it, code it, get the screen, but initial signs showed a quick flash to a black screen most of the time, a "functioning" black screen some of the time, and a crazed green screen some of the time. Worked with the seller, got a new harness shipped. Test installed that today, and I get a fully functional but black screen on reverse every time now. Acts exactly as if it's got a camera and is working, with no picture.
Power is in the fuse box on the open fuse via an add a fuse. Ground has been tried both on the reverse light ground, and under the rear deck (current location). Signal is drivers side reverse light. I have verified good power (BAT), Ground, and Signal (BAT) via a DVM.
Coding was done either via Navigation or via Radio, Byte 3 Bit 6 enabled, and tried the 0B, 01, and 11 codes at the end (Passat NMS, Passat, and Variant/Wagon respectively) per suggestions elsewhere with no change on any of them.
Could it be anything else other than the camera at this point??
