Just quit screwing with investing on trying to fix what is defective and get you an aftermarket. Like this one here on amazon.
Im planning to get it and pull mine out because its showing symptoms of failing as well. After 20 minutes of using mine the music gets weaker, and then cuts out playing at a very low level no matter how high you turn it up. So i just leave it off.
https://amzn.to/2V0Ho66
There are 3 different models.
The first one is well reasonably priced ($106), you may have to get an wire kit if factory harness does not match with radio.
This radio says it supports
- Bluetooth
- Wifi
- Rear Camera / Video Input
- Steering Wheel Controls
- Should have google play store
- Navigation should be google maps
It also looks as if it will fit due to screen bezel shape. Should be a super easy install plug and play.
Hopefully this helps!
Update: Since this supports bluetooth, if device has google play?
You can also get an OBD2 bluetooth scanner connect it to OBD2, get the app from google play installed on radio.
So you can see other gauges such as Boost level, fuel mapping, check engine codes and more.
I think this would be a neat idea to do for my car. You might like it too.
https://amzn.to/377oIao
