2012 Passt TDI SEL PREMIUM 1st OIL CHANGE
Driver_found
Phila
Former MKV Jetta TDI 5M, Former 2013 Passat TDI SE 6M, 2015 Mazda 6 Touring 6m
Wow! You were not kidding. That harness is all in the wrong place. If it was not there it would be so much better.
Here are the pics. Sorry about having to click but faster and easier than the photo tool on here. :)
https://picasaweb.google.com/mtbarr...key=Gv1sRgCPy06ar_zcCiygE#5723910114128635698
https://picasaweb.google.com/mtbarr64/20120324_passat_oil?authkey=Gv1sRgCPy06ar_zcCiygE#5723910172007168066
What is the purpose of the brown braided fabric sleeve shown in your photos? The dealer spilled oil on mine and left it that way..
Driver_found
Phila
Thanks. I had assumed so, but what is it insulating? Would it degrade being soaked with used engine oil? Much the way a fuel leak will mess with rubber hoses and belts. Just curious, besides the fact that they messed up my spotless engine.
TurboDieselPoint
N/A
2014 Passat TDI SE 6-Speed Manual
Well, the insulation is wrapped around the EGR (Exhaust Gas Recirculation) pipe, which basically feeds exhaust directly back into the intake. This is designed to slightly deprive the engine of oxygen to cool down EGTs to lower NOx emissions. Keep in mind, the Passat hardly uses this system (though it does use it a little) due to the fact it uses urea to clean up NOx in the exhaust, rather than using excessive EGR to suppress the potentially helpful high EGTs. Less EGR means the engine runs at higher combustion temps, which increases efficiency for a cleaner, hotter burn (less soot production for DPF to catch), and also consequently makes so-called "passive DPF regeneration" (DPF regeneration due to naturally high EGTs WITHOUT the use of additional fuel injection events in the exhaust stroke to artificially raise EGTs for a short period of time to regenerate the filter. The use of additional fuel injections like I mentioned above is called an "active regeneration." Passive regenerations don't need those additional fuel injection events.) happen a lot more often, which helps save your fuel economy, oil life, fuel system, CATs, DPF, turbo, etc. since less of the active regenerations are occurring. Plus, less EGR means less exhaust will be channeled into the intake, reducing the buildup of carbon in the intake manifold. Basically, less use of EGR is a VERY good thing!
But, I digress. (greatly!) Sadly, some EGR does happen in the Passat, and when it does happen that tube heats up from the hot exhaust. The insulation is there to protect its surroundings from being burned or melted.
Driver_found
Phila
LoL. A bit more info than I was looking for, but I'll digest it. As far as my other concern, should I worry about this sleeve deteriorating due to oil on it, or 'drive more and worry less'. Cosmetically it looks bad, and my OCD is having a tough time looking at it. Thx for the input.
La Conner, WA
The braided sleeve will not deteriorate due to oil soaking into it. It's very difficult to keep it clean due to the position of it and the oil filter.
Driver_found
Phila
Thanks VeeDub. Driving more and worrying less now.
akafred
ontario
2014 jetta TDI
you could probably hoes the oil out with some brake cleaner.. but don't do it when hot or before driving..
FormerOwner
Alabama
2013 Passat TDI SE 6spd; Former Owner 02 MkIV wagon
Buy your DEF @ your local truck stops... usually is competitively cheaper than most places...
My car used right @ 1 gallon in 10K miles... filled it to the brim.
