MyAvocation
Depends on the dealer.What does the free 3 year maintenance cover? Is the dreaded adblue covered or is that more $?
The additive is just used in the exhaust system. The improved economy is due to the engine tuning being able to perform better (dirtier emissions) with the extra emissions being cleaned up by the UREA in the SCR (2nd catalyst).Adblue UREA is the best thing they have come up with so far. Really works well in a big diesel pick-up by increasing fuel economy and its cheap and the price is going down. I think UREA vehicle will be worth more at trade in time.
Yes, UREA is UREA from what I have heard. Kind of like Kleenex's being the name brand (AdBlue) and the generic (DEF).Are DEF products and Ad Blue interchangeable?
Good tip! ThanksTo repeat: VW Adblue system needs a special nozzle to fill the tank. That nozzle is what's on the VW Adblue bottle. So, some have purchased a single bottle from VW, and when empty, cut the top of the bottle in a manner that allows you to use it as a funnel.
Yes. Available at most local auto parts stores. Follow tdiatlast's recommendation of buying one bottle from VW so you have the special nozzle. Refill with generic DEF when that bottle is empty.Are DEF products and Ad Blue interchangeable?
AdBlue is widely available, inexpensive and allows the large Passat to get ~50 MPG. Nothing dreaded about it. Place your order!What does the free 3 year maintenance cover? Is the dreaded adblue covered or is that more $? the adblue and biodiesel limitation are the two things that have kept me from ordering a new Passat. BTW, I'm converting back to B100 in a couple of weeks in my B4....
Incorrect.
Is the drain plus easily accessible? Any obstructions or panels you have to remove to get to it? Would love to see detailed write up with video or pictures for oil change. Thanks.
Of the 69 Passats in your link, only 13 of them provide enough information to determine transmission type, 4 of which are manual.Not that it hasn't or won't happen, but check on Fuelly.com to see who is getting close to or over 50 MPG, and you'll see it's more likely to occur with a 6M. I haven't seen a single SEL with a 50 MPG tank yet, over a 4 tank fillup average. NoBlueScreen is the only one to average over 50MPG on Fuelly that I've seen.
My own take on it, is that the DSG will be hard pressed to even see 45 MPG if driven at 70 to 75 MPH. The higher the speed or rpm in any gear, the higher the parasitic losses to drive the oil pump in any gear the DSG is engaged in. Keep in mind, this motor reaches peak torque at 1500 or so rpm... so the clutch has to have enough oil pressure to keep the clutch tightly engaged and not slipping. That pressure at anything over 1500 rpm is excessive pressure generation and adds to parasitic losses... which is probably why the DSG shifts so soon in Drive mode, to increase fuel efficiency and minimize those parasitic pumping losses.
These are real world observations here... form your own conclusion on MPGs. http://www.fuelly.com/car/volkswagen/passat/2012/diesel l4/sedan
The overall for the 68 Passats that didn't claim 93 mpg is 43.59 mpg per tank. 50 is doable if you don't drive the ever-popular 70 to 75 mph, which you yourself said breaks almost every speed limit, so people shouldn't be going that fast in the first place.
Whatever happened to the initial oil fill being changed after just a few thousand miles? Regardless of whether a different type of oil is used for that purpose, how come these engines don't (or are said not to) require this any more? Can it help to do it regardless? E.g. change once at 3k, then 10k and back on schedule?You are wasting money changing it that early.
Manufacturing techniques have improved immensely, as have finished sealing surfaces of the metal lacking previous roughness. Motor oils too have improved. The net results make 10,000 miles on the second oil fill you are driving on now (the first oil fill was in the test bed before your motor was installed in the chassis) more than adequate, with the use of full synthetic oils.Whatever happened to the initial oil fill being changed after just a few thousand miles? Regardless of whether a different type of oil is used for that purpose, how come these engines don't (or are said not to) require this any more? Can it help to do it regardless? E.g. change once at 3k, then 10k and back on schedule?
X2Manufacturing techniques have improved immensely, as have finished sealing surfaces of the metal lacking previous roughness. Motor oils too have improved. The net results make 10,000 miles on the second oil fill you are driving on now (the first oil fill was in the test bed before your motor was installed in the chassis) more than adequate, with the use of full synthetic oils.
Part no: 90813202 - same screw as the 06 and 11 cars I have.Drain plug info please?
