2012 Passat MAP sensor issue
Grizz87
Alton, IL
2012 Passat TDI
so my sister has a 2012 Passat. Her MAP sensor is bad. When we put a new one in the car runs even worse. Does the new one need to be programmed in VCDS???
x1800MODMY360x
AZ, USA
2013 Passat TDI SEL
Check to see if the wiring is bad, it usually by the oil cooler heat exchanger and can melt wires.
Grizz87
Alton, IL
2012 Passat TDI
didnt see any bad wires. if we put the original back in it will drive fine but throws codes. if we put the new one from VW in it hardly runs.
